No Spark.. Please Help..
Old Nov 28, 2006 | 07:05 AM
XJPete87's Avatar
My 91 3.0L V6 has no spark. I've checked everything I can think of. tried new coil and ignitor. New wires, rotor, and dist cap. Checked pick up coil resistance and checked to see if the coil is getting 12V.. What am I not thinking of? Anybody have something else to check? I am at a loss. Thanks.
Old Nov 28, 2006 | 07:13 AM
MonsterMaxx's Avatar
EFI fuse?
Old Nov 28, 2006 | 07:14 AM
dcg9381's Avatar
You've got a few main options left:
1) Signal generator out of the distributor (likely) - you can ohm this out per the FSM. You can also test it via checking for continuity... At least you can on the 22RE signal generators...
2) ECU (less likely)
3) Connections between components.
Old Nov 28, 2006 | 03:00 PM
toyota_mdt_tech's Avatar
Does the "check engine light" come on with the key on?
JPL
Jan 2, 2013 04:01 PM
Jeep Killa 99
Oct 13, 2012 01:09 PM
carpedevus
Jan 16, 2012 10:44 AM
forbiddenera
Sep 3, 2010 09:10 AM
t100
Apr 12, 2006 06:27 PM
