brake?
Old Nov 24, 2006 | 06:03 PM
doc76239's Avatar
brake?
So I need to replace my pads and rotors. Is there anything else I should do while I have the brakes and rotors off my 4runner? I have never pulled 4runner rotors, anything to watch out for? Any help or ADVICE WOULD BE GREAT.
Old Nov 24, 2006 | 06:37 PM
doc76239's Avatar
Sorry those are not very specific. I was just wondering if there was any hidden things to watch out for.
Old Nov 25, 2006 | 07:36 AM
eric-the-red's Avatar
The pads are easy, just remove the spring clip and pull out the pins, and the pads come out. The rotors aren't so easy, you have to remove the hubs to get them off.
Here's a write up for removing the front hub assembly.
http://www.off-road.com/toyota/wheel_bearing.html
The cone washers can be fun to get off, especially if they've been on there for years. I usually tap the side of the hubs to loosen them, some people hit the ends of the studs with a brass rod. Whichever method you use make sure you leave the nuts on a couple of threads, otherwise you'll spend the rest of the day hunting down the missing cone washers, sometimes they fly off. You'll need a 54 mm or 2 and 1/8" socket as well.
Seperating the rotor from the hubs can be a pain too. It's bolted on from the back with 6 bolts, which are very tight. The method I use is to put the hub upside down in a wheel lying flat on the ground, with the lugs in the 6 holes in the wheel. Then stand on the tire and rotor and use an impact or long breaker bar. The rotor will probably be rusted on the hub as well so you'll have to pry that off.
Youll want to repack the wheel bearings and you should replace the inner grease seals, get 2 new ones before you start. If the bearings look worn, corroded, blue from heat then you might want to replace them.
I'm so glad I have a 3rd gen now, I can replace the rotors in less time than it took to write this.
Old Nov 25, 2006 | 11:57 PM
doc76239's Avatar
HAHA, thanks for the info
Old Nov 26, 2006 | 04:36 AM
86SR522REEFI's Avatar
Yea just take the truck to a shop and have them cut the rotors on the truck. They have a machine to do that, that way you wont have to repack the bearings
Old Nov 26, 2006 | 08:30 PM
curtiswyant's Avatar
I would replace the bearings and seals...good maintenance even if you don't need it. Also check your hoses and brake lines...depending on mileage/location, etc...
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
fabing455
Sep 7, 2015 08:08 AM
Scatterbrain
Sep 3, 2015 06:46 PM
