A340H (AUTO) using Dexron III
Old Nov 21, 2006 | 09:07 AM
Guardian_Saint's Avatar
Quick question,
Anyone with the auto A340H using Dexron III instead of the Dexron II it recommend? Any problem at all? and the good vs. the Dexron II.
Old Nov 21, 2006 | 09:14 AM
gohawks's Avatar
I use Dexron III in my auto. Shouldn't be any problems. It is backwards compatible with II. I don't think you can even get Dextron II anymore.
Old Nov 21, 2006 | 09:51 AM
95RunnerSR5's Avatar
yeah, dextron III is better that dextron II, they dont make II anymore but III is just fine to run
Old Nov 21, 2006 | 10:02 AM
mt_goat's Avatar
I used Mobil 1 ATF in mine.
Old Nov 21, 2006 | 03:41 PM
Redline oil offer Dexron II which I use it and last time it was low and went on to buy a quart of toyota ATF and now it is acting weird so I am planning to change the fluid which thinking of using Dex. III, but thanks I'll try Dex. III..
Old Nov 21, 2006 | 03:45 PM
toyota_mdt_tech's Avatar
Dexron III superceeds Dexron II
Old Nov 21, 2006 | 04:37 PM
trythis's Avatar
I called the dealer on that same issue at the parts store when I couldn't find DextronII. They said it made no difference. Dextron4 was fine too If I recall correctly.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
TheBFA
Feb 15, 2020 06:55 AM
dirk89
Oct 1, 2015 05:15 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
May-39
Sep 6, 2015 01:05 PM
