89 toy troubles
Old Nov 25, 2006 | 03:07 PM
buckcreek's Avatar
89 toy troubles
hello members, first is this is a very good site lots of info.
heres the deal I have a 89 toy 4x4 with a 3.slow that has dropped a rod and locked up tight. Today I found a 88 toy. 4x4 with a 22 manual setup in it that had been rolled over there is not a piece on the truck thats not damaged but the drivetrain looks to be in good condition it also comes with a front axle to do a sas. he asked 400.00 for the entire truck do you all think that I can swap the engine and transmission/transfer case in to my 89...????
Do you all think that this a fair price, and other than changing the ecm and wiring harness how much trouble to make this work?
Old Nov 25, 2006 | 03:13 PM
95RunnerSR5's Avatar
are you sure its an 88? 85 was the last year for a solid axle. also i would try to start the truck up first and see how it runs. it dont seem like a bad deal at all if the drivetrain is in good shape
Old Nov 25, 2006 | 03:24 PM
buckcreek's Avatar
I am sorry I didnt make myself clear it has a stright axle in the bed of the truck for a sas swap. my bad.
Old Nov 25, 2006 | 06:52 PM
buckcreek's Avatar
anyone????
Old Nov 25, 2006 | 07:18 PM
dcg9381's Avatar
Does it run?
Old Nov 26, 2006 | 05:26 AM
buckcreek's Avatar
dont know for sure was running when he wrecked it but now the rad. and hood are locked together going to have to take the front end lose to get in to the engine bay.
Old Nov 26, 2006 | 07:39 AM
hmm...it all depends on what chance you want to take. if the 400 isn't a big deal to you then go for it..
Old Nov 26, 2006 | 04:38 PM
buckcreek's Avatar
well 400 is a lot to me but i have been looking for a replacement for the 3.slow and can not find anything that is in fair condition that is under 1000.00 or more. I have looked at putting in a 4.3 chevy but the adapters and hardware comes to around 700.00 not to amention the cost of the engine.
If the 22 is in fair condition and if the wiring harness will work on the 89 I might be able to get my truck running before the snows flys, for a cheaper than going the other way.
Can anyone tell me if the wiring harness and ecm from the 88 work in the 89? Or will I have to do some mods to get it to work?
Old Nov 27, 2006 | 11:10 PM
buckcreek's Avatar
anyone
Old Nov 28, 2006 | 09:18 AM
Leprechan's Avatar
I don't know if the wiring harness will plug in but you can always rewire the plugs that go to the chassis wiring or swap everything from front to back. The Motor mounts will need to be moved, so if your not comfortable welding or you don't have somebody that will weld it for you I would pass. I am currently swapping a 22re from a 92 p/u into a 94 runner that had a v6 and my wiring is for the most part the same. I will be able to plug engine harness into the chassis harness via the 3 plugs by the ecu. I have not moved the mounts yet but they need to come a few inches forward and they are at a slightly different angle. After the mounts are moved its a bolt in for the motor/tranny. You will have to swap gauge clusters if you want your tach to work. If your truck had abs then you will have to find powersteering lines from a 22re truck that had abs or make your own. There are other odds and ends you will find along the way but its not that hard of a swap from what I have found so far.
Old Nov 28, 2006 | 11:10 PM
buckcreek's Avatar
thank you for the info. did not think about having to weld in the motor mounts, i quess i was thinking that the frames were to same. but i have a welder so that will not be a problem..
voiddweller
Oct 2, 2015 07:47 AM
Matthew Perez
Sep 28, 2015 05:43 PM
oldblue
Sep 28, 2015 04:07 PM
Boomer8404
Sep 17, 2015 07:59 AM
128keaton
Sep 3, 2015 05:09 PM
