'87 turbo 4runner drivetrain questions
Old Nov 28, 2006 | 10:04 PM
Numbchux's Avatar
so I just bought this '87 turbo 4runner. it's got an automatic (as far as I can tell...they all do).
I'm starting to look at upgrade parts, gearsets, lockers, etc.
what I'm wondering, is if I would get parts for a 4- or 6-cyl.
obviously it's a 4-cyl, but I had heard that the turbos had the same rear end as the V6. is this true? how about the tcase?
Old Nov 29, 2006 | 12:16 AM
Trumpfan's Avatar
http://home.4x4wire.com/erik/diffs/#top
http://www.well.com/user/mosk/
http://22returbo.net/#
Try these links: mucho info
Old Nov 29, 2006 | 03:55 AM
waskillywabbit's Avatar
Check out my website for those parts you are talking about and let me know if I can help you out with something.
Old Nov 29, 2006 | 06:16 AM
leiniesred's Avatar
The quick answers:
The turbo4 rear diff is the same as the V6 rear diff. 4 pinion gears in the diff carrier, giant pinion shaft bearings, heavier housing.
Easy way to tell: 4 ribs on the outside of the turbo/v6 rear diffs. Only 3 on the 4 cyl diffs.
So yes, talk to wabbit for your gear/ locker parts for your turbo/V6 rear diff. The front is the same as all the other 7.5 IFS fronts.
The T-case is integrated with the automatic transmission. Not much you can do there except get another cooler and keep the fluid clean.
Old Nov 29, 2006 | 10:35 AM
Numbchux's Avatar
thanks for the links. I haven't seen a couple of those before....
but I figured someone could just tell me.
and I'll keep you in mind, wabbit. I like what I see!
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87turboPA
Jul 12, 2015 07:49 AM
skoti89
Jul 6, 2015 07:45 PM
karbin
Jul 5, 2015 11:37 PM
