Need help removing throttle body
Old Nov 28, 2006 | 09:14 AM
xdogg's Avatar
Question Need help removing throttle body
I will be removing the throttle body for the first time tonight. Any tips you might have for me?
I read the http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml how-to guide, but it didn't get real specific. How much coolant will drain out? Will I need a new gasket to install or anything?
About how long would it take to remove the throttle body and replace the TPS? Thanks so much for your help!!
Old Nov 28, 2006 | 09:33 AM
4Crawler's Avatar
Probably a cup or two of coolant will come out, or drain a quart or two from the drain petcock on the bottom of the radiator then pour it back in when finished. 4 bolts hold the TB in place, there is a gasket between the TB and intake plenum that you could replace if needed.
Old Nov 28, 2006 | 09:34 AM
neilan's Avatar
well first of all when you unhook to collant line basically no collant will come out if you pinch it with pliarswhen you pull it off and then plug it with a bolt befor you let go. As far as romving the throttle body the pricible is easy. Removel 4 bolts and take it off but if yours was on there for 200k like mine then the gasket is probably stickign it on the pretty good. I had to use a block of wood and hammer to get mine the break free. As far as the tps i have never replaced one.
Old Nov 28, 2006 | 10:09 AM
snap-on's Avatar
Id say a couple of hrs if you have all the tools and know what your doing. A little longer if your "feeling" your way though it.
Old Nov 28, 2006 | 11:19 AM
xdogg's Avatar
Do I need to remove both the TB and the coolant line, or just one or the other?
Which coolant line is it? The big one like 1.5 inches in diameter right next to the TPS? Sorry to be such a newb, I just don't want to screw this up!
Old Nov 28, 2006 | 11:41 AM
4Crawler's Avatar
There is likely a large air hose and on the later model throttle bodies, a coolan line for the idle air valve. Early TBs have that valve separate. Simple answer is disconnect whatever is connected to the TB (air, coolant and vacuum lines, the throttle cable and TPS wiring) in order to remove it and then connect those items back when installing it. Mark/label everything well, take pictures before and it should be no problem.
montanatruck
Feb 26, 2017 07:07 AM
Sep 4, 2015 09:27 AM
jetpilot
Aug 15, 2015 06:48 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
