How to remove grille?
Old Dec 3, 2006 | 12:49 PM
doc76239's Avatar
I search the forums and am having a hard time finding info on how to remove the grille in my 92 4runner. Help. I have taken out the corner parking lights, and popped the retaining clips along the top of the grille, and removed two bolts on each side of the grille. What else am I missing? i reallly can't see anything from under neath. Any help would be great.
Old Dec 3, 2006 | 12:54 PM
bruzer's Avatar
If I remember correctly, I think once you get all of the screws and stuff out, some of the screw points are also little clips on the back side. So you actually have to squeeze them and then push them out. Like I said, thats if my memory serves me correctly. Its been awhile since I had to remove the grill from a yota or any other vehicle for that matter. Good luck!
Old Dec 3, 2006 | 01:09 PM
doc76239's Avatar
thank you any one else?
Old Dec 3, 2006 | 01:55 PM
Silverunner's Avatar
I took off my front bumper first, and from what I remember there were 3 clips on the bottom just like the ones on top. The bumper has 2 bolts on each side. Push each clip in then it should slide out. Hope this made sense.
Old Dec 3, 2006 | 03:48 PM
doc76239's Avatar
Yeah that makes sense. I figured there were some of thos eclips under there, just couldn't see them?
Old Dec 3, 2006 | 04:25 PM
slosurfer's Avatar
You can see where two of the lower clips are. One dead center just above the bumper. One just to the right of the tranny cooler and there will be a matching one on the left side.
Old Dec 3, 2006 | 04:41 PM
Cebby's Avatar
Those clips break easy by BTW...
Old Dec 4, 2006 | 01:20 PM
doc76239's Avatar
Thanks for the photo, and Yeah i kno0w those whimpy clip snap like kindling
Old Dec 5, 2006 | 06:03 PM
dstrick32's Avatar
You also have two tabs or pegs that are on ths parking/corner light that fit into holes in the fender be sure to pull out from fender before trying to pull the grille straight foward.
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
old87yota
Sep 9, 2015 12:39 PM
justdifferentials
Just Differentials
Sep 8, 2015 03:15 PM
justdifferentials
Sep 8, 2015 03:13 PM
4x4-runner
Aug 3, 2015 07:14 PM
