Leaking fuel pressure regulator
Old Nov 28, 2006 | 12:33 AM
Asha'man's Avatar
I think I've finally found the cause of my recently-atrocious gas mileage. When the truck is running and for a short time after I shut it off, I can see fuel dripping about twice per second off of what appears to be the fuel pressure regulator. I haven't taken things off to see if that is indeed what's leaking, but if it is the FPR, how hard is it to replace? Or is it just an O-ring seal inside that might be leaking?
Knew there had to be a reason why my truck smells of gasoline after it sits for a few minutes.
Old Nov 28, 2006 | 04:17 AM
Yoda's Avatar
Disconnect the return hose, vacuum line and unscrew it. I might have undone the EGR tube for access.
Old Nov 30, 2006 | 10:48 PM
84sr5yoty's Avatar
Is it the pressure regulator or the pulsation damper? Fuel pressure regulator is near the firewall, pulsation damper is near the front, under the intake manifold. Both are known to leak with age.
Old Dec 1, 2006 | 12:45 AM
Asha'man's Avatar
I was wondering if this truck had a fuel pulse dampener, as my Mustang does. It is indeed the one in front, so I guess that's it. Is it the actual dampener that goes bad or just the O-ring or seal that seals it?
I think I'm getting about 8 mpg lately with this fuel drip.
Old Dec 1, 2006 | 03:08 PM
84sr5yoty's Avatar
I know that the screw in the middle sometimes backs out to the point where it falls out and begins dripping fuel through the hole.
They're not repairable so you'll need to get a new one. I believe they're a dealer item only.
Old Dec 1, 2006 | 03:42 PM
dcg9381's Avatar
There is an o-ring.
jbv808
Aug 6, 2021 04:47 PM
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
msane99
Jul 17, 2015 10:13 AM
