vibration issue
Old Dec 2, 2006 | 02:54 PM
jimscat's Avatar
vibration issue
or atleast I think it is. I have read most of the vibration posts and there is not one with the exact vibration I seem to have.
I have a 93 extended cab 4x4 22re 90000 miles. I bought the truck in march and have replaced the clutch, 2 u joints, tires (balanced twice) and i still have a vibration from 40 and up. Today I noticed that I had a vibration in the steering wheel at idle in neutral.
After reading, i seems I could have the drive shaft ouf sink or unbalanced.he vibration at idle, possbly motor mount? Idle is right on and no other issues.
Any suggestions? Jim
Old Dec 2, 2006 | 02:56 PM
silversup's Avatar
I want to know this one
Old Dec 2, 2006 | 02:59 PM
rocket's Avatar
Originally Posted by jimscat
motor mount(s)?
That would be my guess. Have you checked them?
Old Dec 3, 2006 | 08:59 PM
ToyYoda's Avatar
check your driveshaft bolts
Old Dec 4, 2006 | 02:51 AM
jimscat's Avatar
thanks guys, everything in the driveline is tight and i have been able to run about 100 miles and i think most of the vibration above 40mph was unbalanced tires. the majority of the vibration i now feel is in the steering wheel at all speeds. I did find a bad ball joint that I need to replaced before sticker runs out.
Thanks guys
Jim
Old Dec 4, 2006 | 06:48 AM
sloth!'s Avatar
Vibe at idle is most likely motor mounts or tcase mount. AS far as the vibes at speed I would guess tires but you can also check your center bearing on your rear dshaft, they go bad quite often. Also depending on the mileage it could be your output on the tcase, usual problems are flange is loose or output bearing is worn.
Old Dec 4, 2006 | 09:51 AM
EineZweiDreiVier's Avatar
my friend had vibration in his steering wheel at idle which mostly went away once he started accelerating... If I remember correctly he had a blown valve, or so he said.
bigjstang
Jun 2, 2025 03:56 PM
nvdesertrunner
May 11, 2020 08:18 PM
crammit442
7
Nov 29, 2017 12:30 PM
raptor510
Aug 19, 2015 02:15 PM
rjtrials
Aug 6, 2015 07:25 PM
