sas swap question about gears
Old Nov 29, 2006 | 05:12 PM
meswoleshane's Avatar
1) I'm gathering parts for a sas swap and finally found an axle, its an 80' front axle, the gears are 4.375, is that close enough to my stock 4.30's untill I can upgrade them later, I probably won't use the 4wd for anything but mud.
2) This axle from what I've read this axle doesn't have a full truss, but it looks like the truss goes from the diff to the driver side u-bolt, also I read that the caliper bolts on differently then the newer straight axles but it looks like the same mount as my 4runner.
any help would be great!!!
Old Nov 29, 2006 | 05:30 PM
4Crawler's Avatar
Gears should be close enough for off-road use.
You can get aftermarket trusses to add to the top of the axle if desired, AllPro, TrailGeal, MarlinCrawler all have them. Early axles have different rotor mounting (6 bolts vs. 2 bolts) IIRC.
Old Nov 29, 2006 | 05:44 PM
so the 86-95 caliper's will bolt on? what do I do for sloted rotors now? I'm supposed to use older fj40 rotors but which year since its a 80 model axle?
Old Nov 29, 2006 | 06:12 PM
fork's Avatar
Just confirming that this is what you're talking about:
Old Nov 29, 2006 | 07:09 PM
waskillywabbit's Avatar
I got all the parts you need...call or shoot me an email.
Old Nov 29, 2006 | 07:13 PM
fork, not the truss on the top, the axle I'm looking at has a factory buit in truss on the bottom.
I can get this axle for $70 complete from side to side, so I think its a good deal.
does anyone know about the vented brakes though?
Old Nov 29, 2006 | 07:18 PM
waskillywabit, I'll probably be ordering some stuff from you in the future.
Old Nov 30, 2006 | 05:30 AM
On the 79-85 Toyota SFA you can upgrade to vented rotors and the big 4 piston IFS calipers. You need the vented rotors that have 8 holes, 6 for the wheel studs and 2 to bolt onto the SFA wheel hub. You will probably need wheel spacers with the big calipers or a shallow backspacing on your rims like 2" or do the IFS wheel hub swap, or the big calipers are gonna rub on the rim.
Just look on my website...all the parts you need are there. Again, if you got questions, just shoot me an email.
Old Nov 30, 2006 | 08:51 PM
another question, what about the sway bar? should I get the stock sway bar with the axle and mount it on my 4runner? this truck is going to be driven mostly on the street so I think I need one.
also is there anything I can do to make the steering work with the stock parts or do I need the crossover aftermarket stuff?
Old Nov 30, 2006 | 08:58 PM
4Crawler's Avatar
Sway bar:
- http://home.4x4wire.com/erik/4runner/sas/#swaybar
Crossover steering is the best option, or go old school and do this:
- http://www.off-road.com/4x4web/project/projtoy.html
mskalmus
May 28, 2017 07:51 AM
crashburnoveride
Aug 28, 2015 09:20 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Jnkml
Jul 6, 2015 01:20 PM
