Starting problems after rebuild
Old Nov 20, 2006 | 05:46 PM
Firefightertaco's Avatar
Well after dropping back in my engine (22re) got every thing hooked up and go to crank it and i just get a single click, i think its just the starter im gonna take it back off and take it to advance auto to get it tested, but could if possiblely be a bad ground some where, also i saw that my injectors leak really bad now cause of the seals that were all dry rotted, i was wondering where i could get some new ones.
Old Nov 20, 2006 | 06:52 PM
Any one had this problem before?
Old Nov 20, 2006 | 06:57 PM
yota_krazy's Avatar
As for the starter, it sounds like a classic case of bad contacts. Although since you just RNR the engine, be sure to check all of your ground connections. As for the leaky fuel injectors, I would just get injector seals at the dealership although any aftermarket ones will probably be fine.
Old Nov 20, 2006 | 07:54 PM
dcg9381's Avatar
Wires ok? everything grounded? Battery alright?
Did the motor turn over by hand, at least 360 degrees?
Old Nov 20, 2006 | 11:21 PM
8422r4Runner's Avatar
Had this problem with mine when I first got it. On my 84 22r, the power from the battery hooks straight on the starter, with a smaller leg going off to the fuse box. So where is the 2nd leg or ground leg for the starter. On mine there was a small wire that ran from the block to the frame. But when the last owner rebuilt the rig he never reconnect the ground strap. For a quick check I ran a jumpper wire from the ground on the battery to a spot on the block. Motor turned over like it was happy and fired right up. So I then ran a ground wire from the battery to a spot on the motor. I have had no more problems with the click or real slow turning starter when it does spin.
Old Nov 21, 2006 | 04:23 PM
i can hear and feel the starter solenoid click but it just dosent spin, do u think it would be a bad stater or could a ground cause that?
the1998sr5
Oct 19, 2016 12:48 PM
Crazychris1871
Jun 27, 2016 10:38 AM
jennygirl
Nov 17, 2015 11:24 AM
85run
Jul 8, 2015 11:20 PM
aciorba23
Jun 29, 2015 04:18 PM
