Tokico Shocks...
Old Nov 23, 2006 | 09:07 PM
Tigerstripe40's Avatar
Tokico Shocks...
I got a set of Tokico shocks from an FJ Cruiser (Stock shocks) from a buddy.
I am going to be fixing the bumpstops, and adding coil spaces in the rear of my '91 4Runner and figured I might try these as a replacement for the decidedly shot rear shocks.
I might have to fab something up.
I will take pics and reply to this thread with results.
What is the stock shocks' stroke length?
Old Nov 24, 2006 | 10:31 AM
Elton's Avatar
why not just buy shocks for the 4runner ?
Old Nov 24, 2006 | 10:32 AM
04 Rocko Taco's Avatar
cause these were free ELton, come on!!!
Old Nov 24, 2006 | 10:33 AM
AND, its way better to spend $100 fabbing up a system to use free shocks than paying $50 for new shocks, everyone knows that!!
Old Nov 24, 2006 | 10:49 AM
Because these were free, and with the spacers I am installing, I need a longer shock anyhow.
Old Nov 24, 2006 | 11:12 AM
Elton's Avatar
ahh i see they where free fab them up
Old Nov 26, 2006 | 07:18 PM
Just got finished repairing the bump stops.
This is what I started with:
The hardest part of the whole project was removing the old stock shocks.
The hold down nuts at the top were rusted to the stud. Took me a while to get them out.
I drilled a hole in the shocks to release the gas per the FSM. 1 shock released gas, 1 did not.
I was able to recover the stock bump stop by grinding the piece of rust it was attatched to out, then I dressed it up nicely with the flap wheel on my grinder.
Next, I had to address the rusted out spring buckets
I cut the rusted out spring buckets down enough for me to get a level surface,. Then I ground off the rust and corrision to shiney steel, and sprayed the inside of the holes with POR-15 Metal Ready to convert the rust to a phosphorous coating. After that was dry, I sprayed the inside of the buckets with some cold galvanizing compound and let that dry.
Then I welded 2 discs of scrap steel that I had previously prepared by drilling a hole through the center, then welding a nut onto the other side for the bumpstop to bolt to.
After that was all done, I ground down some of the boogers I put into the buckets, then rattle canned them to help prevent rust. AFter that was dry, I bolted the bumpstops on
Next I installed the springs, some 1.5" spacers, and the FJ Cruiser shocks, which fit perfectly, and are about 2" longer than stock.
And finally, A link to the rest of the pics
http://photos.gunzenbombzpyrotechnic...Name=bumpstops
bamachem
818
Nov 16, 2010 09:37 AM
shiftMX
Jan 26, 2007 08:04 AM
UNR.Grad
7
Sep 14, 2006 07:35 AM
Mr. Bob
41
Jul 25, 2006 08:45 AM
iGGz
Mar 1, 2005 02:03 PM
