PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 [224] 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 5 Speed Conversion O/D Light Problem
  2. Vaccum Lines!
  3. Yota Down! Shorted E1 to +Battery (Will it kill the ECU?)
  4. Replacing Shocks
  5. how do you know the gear ratio? 2nd Gen. 4Runner, 3.0 5spd.
  6. 7mgte '94 4X4 pickup project suggestions
  7. Where to mount shocks on axle?
  8. HD Tie Rods for IFS
  9. Trans Trouble
  10. driving with a rattly timing chain
  11. 16x7 33"s?!?!?!?!
  12. Rear springs sagging or front lifted?
  13. sloooowwww power windows
  14. Muffler?
  15. Making a Vacuum Pump
  16. 94 pickup exhaust
  17. 22R Bouncing Fast Idle
  18. 1986 Toyota PU 4wd 22R-E, O2 sensor wire missing
  19. 92 4runner
  20. Umm... What's this?
  21. Does anyone know a good mechanic in Kelowna?
  22. gearing question for the gurus
  23. Need a header, and soon
  24. Clutch Gets Stuck
  25. Rear end help.........
  26. 35''s?
  27. clunk when stopping
  28. 302 swap what is a prefered trans?
  29. Rear axle in out play... Pick ur brains!
  30. afm results and qs
  31. Electrical Problem 91 4Runner
  32. winch problems
  33. oil pan gasket problem
  34. CV joint / shaft...how do I know it's bad and what can I expect upon replacement?
  35. oh no truck fire
  36. water pump question
  37. Odd Noise
  38. Chain or Gear
  39. Little buddy's been sittin'....
  40. 4.88 gear question.
  41. 400 horse 3.0?? Have a look...
  42. 4 The tanny guys
  43. Went mudding... Now idiot lights are on!
  44. Delay in starter turning on
  45. Going from 32x11.5 to 33x10.5 on 4.10's, anyone done it?
  46. Towing Capacity?
  47. Comp Cam EB springs
  48. replace 3.0 with 22r?
  49. Picked up a new yota!
  50. Anyone know anything about this?
  51. lift kit
  52. Loudest, but best sounding muffler?
  53. Could it be #4 valves?
  54. Problem while braking to loose RPM/Power...
  55. Horrible engine carnage, need advice
  56. Best place to buy a CAT???
  57. any power steering system tutorials?
  58. rear shock question
  59. ATF leaking from bellhousing
  60. Hot Topless Photos Not Work Safe!!!!!
  61. Is 55mm socket same as 54mm?
  62. evap canister
  63. Oil Pick-up Tube
  64. emissions routing for 3 L
  65. Rear Sag Fixed....
  66. pickp bed
  67. 92 pickup 4x4 wheel hub?
  68. Knock Sensor Needed!!!
  69. 2nd Gen 4runner with cruiser coils and 1" bl pics???
  70. 99' 3.4L erratic idle problem, P0505 code
  71. 400 hp 3.0 Ivan Steward motor
  72. 94 Pickup IFS lift on a 4runner?
  73. 93 V6 Won't Start?
  74. got it sprayed -now buffing
  75. 90 4runner shocks
  76. fuel pressure regulator
  77. new fan clutch - performance loss?
  78. Snorkels, any ideas or designs?
  79. Clinometer?'s
  80. pinion seal,overtightened nut
  81. CB picking up engine noise?
  82. Mods for 3vze?
  83. Fender Flare Manufactures
  84. Latest turbo incarnation 22re turbo
  85. 3.4 or 7MGE... why?
  86. 2wd drive train(22re-5spd) in 4x4 chassis (Will it bolt up?)
  87. Isr Mod Done Today,pics & What I Noticed.
  88. Still didn't pass e-test, but readings are now half
  89. Hi-Lift Mounts
  90. Hot air through vent
  91. ifs 7.5 and 2wd 7.5 interchangealbe?
  92. Just lifted the 4runner and am now looking for new shocks
  93. OK, Im convinced (oil filter brand)
  94. converting to Mobil1 next oil change, would you recommend drop the oil pan
  95. Truck wont start?
  96. Fuel Damper...
  97. Does my 4Runner need mudflaps in AZ?
  98. Ranch 4" lift? what kind is it.
  99. where to buy tailgate letters ?
  100. injectors, when to change?
  101. hard starts and doesn't like quick accelleration
  102. OEM or aftermaket Cold start Injector?
  103. removing rotors question
  104. replacing oil pan ? easier to drop the front diff ?
  105. WTB: 90 4runner grille
  106. Rune's 3.0 rebuild thread
  107. I hate to trash the party - Sonoran Steel IFS Tuss Install
  108. heater core?
  109. My 4 Seated Buggy
  110. 84-88 Center console questions
  111. 1986 toyota northstar edition pickup
  112. cant get 4runner runnin
  113. How loud are these mufflers?
  114. polyurethane bushings & SAS
  115. Electrical short
  116. cleaning plenum and valve cover
  117. my seafoam method
  118. Pics of a 4runner I am looking to pick up
  119. What? Loose shifter
  120. great article about oil sludge
  121. Starting Weirdness
  122. 1988 Hiace 4x4 2.4 diesel truck
  123. Tranny/t-case fluid
  124. bought a 1990 and 1991 pickup
  125. t-top for 1st gen
  126. Pics of what is kicking my butt - What am I doing wrong??
  127. EGR and Emision Control Stuff.........?
  128. Valve Adjustment How Too...
  129. Post up CRAZY leaf flex please.
  130. swap 22re w/ 3vze ?
  131. What hose / seal is this called?
  132. steering oscillation
  133. A/C Kicks Off in High Heat
  134. Tie Rod Ends
  135. WANTED a bikini top for my 86
  136. AC Questions
  137. 4runner sub installs
  138. SHALZBOT!! Am I 180 out?? '95 3VZE
  139. A/C Drain
  140. Head Gasket Info - FIPG
  141. Quick questions
  142. 2wd lift and tires
  143. what is wrong with my 4 runner?
  144. Tranny fluid filter....
  145. Sugestions for mounting trans cooler on 94'
  146. Timing chain cover leak?
  147. IFS Truss Group Buy
  148. Can any one help
  149. Headers or slap a weld on my old manifold?
  150. clutch?
  151. where do you wrench?
  152. IDler arm answer for bracket lift???
  153. Ideas for an old 4runner??
  154. I swear I'm gonna punch the kid!!! Parents discipline 'yer kid!!
  155. Bl done, shifter problems
  156. A good place to order wheel bearings online?
  157. Paper gasket between tranny and t-case?
  158. Pulled EFI fuse? Keeps running though? Dang toyota :)
  159. Finally Cleaned the Truck Today... 56k, Dont Do It!
  160. HG Repl. 3VZE Almost done - LH Ground plug - HELP!!!
  161. new trans that leaks
  162. need help settling an argument about eng blocks
  163. Chrome Headlight Bezel (90-91 4Runners)
  164. interior years?
  165. I found an almost perfect 92
  166. Push Bar question...
  167. Ok engine wizards....nothing goes in this hole, right?
  168. Where can I find a new oil pan?
  169. Painting oil pan
  170. Part Needed LSPV for 88 4x4 Pickup
  171. Welding a sway bar
  172. XTREME 4X4 design and build ?91 Toyota mini truck on Spike TV!
  173. slang/common terminolgy for hrew, dom, etc...
  174. Driver's side switches don't work??
  175. online wire diagram
  176. Need Help passing e-test
  177. Stock T-Bar Markings
  178. Washer Pump deterioration
  179. looking for differential housings
  180. Add-a-leaf To My Suspension?
  181. 22RE missing
  182. Wash Wax New Roof Rack New Tires Its Like Its Sunday!
  183. wheel bearing q's
  184. what do I need to fix my stock suspension?
  185. Runnin 33x9.50's
  186. OME shocks question
  187. would you guys buy a truck like this...?
  188. 88 4x4 PU brake problem
  189. 31"x12.50" Vs. 32"x11.50"
  190. My Gear ratio?
  191. vacuum line markings
  192. Marlin Crawler front bumper
  193. Bad news for my 4runner.......
  194. 90 and newer mileage
  195. Rear Axle Strength/Swap
  196. Check this out!!!
  197. Bush bumper and roll cage...
  198. Door Panel Removal
  199. Custom IFS Truss / Brace Installed
  200. Can U Answer Q To Crazy Splipage
  201. 22re timing chain tensioner
  202. weather strip help
  203. 2 quick questions regarding head gasket replacement
  204. Calipers sticking?
  205. spray on bedliner questions
  206. Downey 2nd gen Chrome headers $200 in WA
  207. HG or ????
  208. alternative fuel???
  209. Got Me Some New Wheels
  210. Can anyone tell what might be leaking from this tranny pic?
  211. how hard is it to do front wheel bearings?
  212. Replacing engine.....What else d oI need?
  213. Help Id This Diff
  214. Stock 4runner, HOW FAR CAN I TAKE HER?
  215. What would you pay????
  216. Deep Water.....
  217. Was my PO a complete idiot or am I on crack? ATF in Rearend...
  218. Windshield Wiper Switch
  219. heads or long block??
  220. J-D Fab T-1 Questions
  221. Spool for 3rd gen truck... thoughts
  222. lc coils??? appearantly not
  223. Replacement Plastic Parts
  224. cat burglar
  225. Pics (1995 4runners)
  226. New EGR valve + code 71. what gives?
  227. power antenna
  228. code 52 & erattic idle on start up
  229. steering column
  230. Trailer hitch compatibility
  231. AC PROBLEM (Is This Bad) HELP
  232. Newbie 3.4L engine swap questions
  233. Steering fluid leak?
  234. Newbie 88 4x4 pickup
  235. Can I pull my 3VZE with tranny/transfer attached?
  236. a sudden loss of power
  237. A bolt on 85 4runner
  238. Down on power
  239. 87 manual trany question
  240. 5W-30 To 10W-30 Causeing My Ticking?
  241. Electrical gremlins, 3vze
  242. LC Engineering (good/bad)
  243. factory stripes geez...
  244. YES or NO??
  245. Aftermarket gauges
  246. Engine Shake
  247. Project 4Rescue:
  248. Need Help Please
  249. alittle help and or insight plese
  250. Help Balljoint spacers
