93 V6 Won't Start?
Old Jul 24, 2007 | 04:19 PM
atatoy's Avatar
93 V6 Won't Start?
I have a bit of a problem. After supper tonight I went to go to the store and my truck will not start. It has a new battery however it will not even turn over. Could it be the starter contacts?
Old Jul 24, 2007 | 05:54 PM
mtsumedi's Avatar
Did you try to jump it anyways? Alternator could be going out.
Old Jul 24, 2007 | 06:08 PM
CJM's Avatar
CJM
Click and nothing means starter, almost turning over means battery. And cranking but wont turn over is very hard to take a guess at.
If it clicks, then tap the starter hard with a long pole of some sort.
Old Jul 24, 2007 | 06:13 PM
pitpatt's Avatar
check the terminals and make sure they are connected. i disconnected mine and didnt tighten the neg. back up completely and started freaking out before i realized the problem.
Old Jul 24, 2007 | 06:18 PM
tc's Avatar
tc
Not hard! Just firmly.
Auto or manual? If manual, can you bump start it?
Jay351's Avatar
What are the symptoms? If you have a 5sp, did you bump start it?
Check your battery connections.
Old Jul 24, 2007 | 06:21 PM
mtsumedi's Avatar
Not always. I've had plenty of cases where the battery did have enough juice to kick the starter.
sandyota
Feb 4, 2021 11:16 AM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
karbin
Jul 5, 2015 11:37 PM
