oil pan gasket problem
Old Jul 26, 2007 | 08:41 AM
shoff's Avatar
I was installing my oil pan with a new gasket. I put a little red rtv sealant on the gasket and torqued the nuts to 9 ftlbs like the Haynes manual said. The gasket started squeezing out the side. This does not seem normal. What should I do leave it or replace it? Also how the heck do you put a picture up on a thread? I cannot figure it out......[IMG][/IMG]
Old Jul 26, 2007 | 08:44 AM
Kaleb's Avatar
go to tinypic.com and upload the picture. Then copy the code that says "IMG Code for Forums & Message Boards:" into your post.
Old Jul 26, 2007 | 08:56 AM
CyMoN's Avatar
part of the reason is these motors where designed to have sealant on the oil pans not a gasket.
also from my experience red sealant dose not seem to last near as log as the the high temp black or grey silicone that is oil resistant.
this might help also https://www.yotatech.com/forums/f116...umbers-102344/
Old Jul 26, 2007 | 01:22 PM
TORTIS's Avatar
I had the same problem using the black rtv. i took the oil pan off replaced the gasket, used the black rtv and snugged the bolts down, then came back a couple of hours later and snugged some more. i think i ended up with 6-7lbs of torque. i think somebody makes a rubber gasket, but i don't remember who makes it..
Old Jul 26, 2007 | 01:44 PM
CyMoN's Avatar
I did not know yo have the motor out I would remove the cork gasket and use the black high oil resistant silicon only just make sure to not put too much around the dipstick hole it can make it hard to check the oil
smthwsn357
May 1, 2024 07:28 AM
Colington
Mar 8, 2020 09:51 AM
Yota.Jay
Jul 23, 2015 08:08 PM
87blyota
Jul 10, 2015 04:31 AM
Jnkml
Jul 6, 2015 01:20 PM
