clutch?
Old Jul 21, 2007 | 06:34 AM
shoff's Avatar
clutch?
I am looking to buy a new clutch kit. I am running a stock engine that I just bought from Jasper Motors. I do not need a high performance clutch. I need something that is reliable and not going to drain my wallet?
Old Jul 21, 2007 | 07:14 AM
Asha'man's Avatar
Marlin Crawler gets good reviews. I'll know after today.
Old Jul 21, 2007 | 07:19 AM
jd20phill's Avatar
marlin crawler ftw!!!! Going on 3000 miles and not a sigle problem
Old Jul 21, 2007 | 08:05 AM
TORTIS's Avatar
I have the marlin HD, and it has a pretty stiff pedal. I am going to try wabfab next time. All of my driving is in town, very little offroad, but I do pull a trailer and marlins clutch locks up well when towing. I put about 50,000 on it and no probs.
Old Jul 21, 2007 | 09:05 AM
Elton's Avatar
hear nothing but good things about www.marlincrawler.com
norcalsvx's Avatar
i run the centerforce on mine nice pedal feel and i have'nt had any problems so far (the marlin was to stiff for me)
Old Jul 21, 2007 | 09:40 AM
thook's Avatar
Guys....Marlin does have a 900lb (=stock) clutch.
Old Jul 21, 2007 | 10:34 AM
waskillywabbit's Avatar
We have clutches:
http://www.wabfab.org/products/clutches/clutches.htm
Old Jul 21, 2007 | 10:45 AM
thook's Avatar
And so does WabFab....
Old Jul 21, 2007 | 10:46 AM
drew303's Avatar
Search feature is free on Yotatech and if you type in clutch you get a lot of threads, A LOT of threads =)
Old Jul 21, 2007 | 11:57 AM
norcalsvx's Avatar
yea i drove my buddys truck with one (dont the the specs0 i've always had good luck w/ centerforce
Old Jul 21, 2007 | 04:20 PM
HAVOC's Avatar
a side note: I've read on a site that the "step" on the flywheel should be machined so many thousandths for better pedal feel. Is this correct? I can't remember the spec off-hand.
Old Jul 23, 2007 | 09:08 AM
braverex's Avatar
I put the Marlin Crawler clutch in a couple of months ago and have nothing but good things to say. The kit came with everything I needed and went in without any problems. I had my flywheel machined at a local shop for $20 as well. Recommend doing the shifter seat while you are doing the job... mine was in a thousand pieces and for ten dollars more it is worth it!
Old Jul 25, 2007 | 11:28 PM
Robhick02's Avatar
Sorry don't mean to thread jack, was wondering how stiff the 1200lb and 1600lb Marlin or Wabfab are as my clutch in my 87 is literally on its last legs(slips in 3rd and 4th and when starting on inclines). I can handle a little stiffness but don't want to have a clutch that feels like it belongs in an old 1ton full size from the early eighties(the ones that require you to use both legs to engage). Just want something that is going to last a long time and will allow me to pull a 1200-1500lb atv trailer without problems. Either way I want to go ceramic. Any help/advice is appreciated.
Old Jul 25, 2007 | 11:45 PM
pennywize's Avatar
i went to the local napa. got the cheepest clutch and flywheel i could. both out the door for $157. putting them in next week in my '79. its not a DD so it should be fine for a long time
Old Jul 26, 2007 | 12:28 AM
drew303's Avatar
Don't do ceramic. Ceramic handles far differently than semi-metalic organic clutches!
As a ceramic clutch heats up it sticks MORE, which is opposite that of a organic clutch.. However theres literally little to no slippage with a full ceramic clutch. ... I'm sure you'll get real sick of it, real quick.
Pedal feel has to do with the the pressure plate you're using. A 900 to a 1200 to a 1600 ... the higher the rating the more force is needed to counteract that pressure.
I have marlins 1200lb and the feel is perfect IMO. Compared to the stock clutch on an 87 2wd its stiffer but just right. I hate how easy the clutch pedal is in the 2wd.. .. marlins 1200lb is perfect for me.
Old Jul 26, 2007 | 01:40 PM
Robhick02's Avatar
Thanks for the heads up. Someone told me tha the ceramic acted the same as a semi-metalic organic, but lasted longer. Kinda had a feeling that he wasn't right. Good thing i have YT to consult with first.
I agree about the stock pedal feel. Too soft. Leaning towards a 1200lb.
Old Jul 26, 2007 | 01:53 PM
1styota4X4's Avatar
centerforce blew up in my truck....it lost almost all of the material on the pressureplate side and over .33% of the material on the flywheel side....I did a marlin 6 months ago and love it.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
