winch problems
Old Jul 26, 2007 | 08:55 AM
run4her's Avatar
winch problems
i got a 8000 pound winch and when i ran it for the first time it fried some ground wires. What kind of ground should i run?
Old Jul 26, 2007 | 09:12 AM
chimmike's Avatar
it should've had it's own 0 gage grond wire that you should (if you can) connect directly to the - terminal on the battery.
what kind of winch is it?
Old Jul 26, 2007 | 10:49 AM
tc's Avatar
tc
a BIG one
Winches draw a lot of power (as I'm sure you found out)
Old Jul 26, 2007 | 11:55 AM
jht3's Avatar
connect the large gauge ground wire directly to the negative battery terminal.
Old Jul 26, 2007 | 12:00 PM
MMA_Alex's Avatar
the bigger the better. whats the hp/kw rating on the motor? from that you can figure out how many amps it draws @ 12v, and use that to figure out wire size
Old Jul 26, 2007 | 12:41 PM
run4her's Avatar
should i run a ground from the - post to the body to the frame to the motor too?
Old Jul 26, 2007 | 02:22 PM
tc's Avatar
tc
It should have those already from the factory, but they may be loose, corroded, etc and it's worth checking them out and upgrading them if possible.
Old Jul 26, 2007 | 02:32 PM
MMA_Alex's Avatar
as stated above there should be a ground wire going from the negative terminal to the body & frame. thats what the black connector on the terminal is. The issue is that they tend to corrode, and winches use a lot of power, and it can be too much for the corroded grounds to handle, which is why its recommended that you run the ground straight to the batt terminal.
boogiewoogie
Jul 24, 2015 05:10 AM
MTLroadierunner
Jul 20, 2015 03:07 PM
Vargntucson
Jul 4, 2015 12:15 PM
