Can U Answer Q To Crazy Splipage
Old Jul 18, 2007 | 08:35 PM
meagadam's Avatar
Unhappy Can U Answer Q To Crazy slipage
I HAVE A 92 4RUNNER AFTER I DRIVE FOR A WHILE MY miles per hour GAUGE AS WELL AS MY RPM GAUGE STARTS FLINGING AROUND. THEN AT THE SAME TIME MY TRANNY STARTS SLIPPING THROUGH GEARS. iF THIS IS A TRANNY PROBLEM THAT BE OK DO TO THE FACT ITS COVERED BY A WARRANTY . BUT A LITTLE INSIGHT WOULD BE GREAT WERE I DONT GET TALKED INTO PAYING FOR SOMETHING THAT DOESNT REALLY NEAD TO BE FIXED
Old Jul 18, 2007 | 08:40 PM
colsoncj's Avatar
woah there buddy.... ALL CAPS means shouting... no need to shout.
first, are you positive your tranny is slipping? do any other instruments flicker (radio, etc)... when this happens?
Old Jul 18, 2007 | 09:02 PM
meagadam's Avatar
sorry bout that. was in a hurry as far as electrical my lights ect... work fine .and my tranny is actually more changing up and down gears i wouldnt say slipping also my trip and mileage meter moves faster like im actually doing the speeds my mph is reading
Old Jul 19, 2007 | 04:20 AM
colsoncj's Avatar
odd.... i would need someone to verify, but I thought the speedometer (miles per hour) and odometer (mileage accrual) are cable operated and the tachometer (rpm's) is electrically driven. if this is true, then i would assume you have actually 2 problems.
if the speedo, odo, and tach are all electrically driven, then i would assume its a ECU problem. I dont know exactly how much the ECU modulates the transmission, but a larger ECU problem could cause all the above problems.
Maybe someone else can chime in and offer thier 2 cents!
Old Jul 19, 2007 | 04:45 AM
offroad4x4yota's Avatar
Find out which trans you have. is it the A340E or A340H there may be some info on one of my threads that might help you out
https://www.yotatech.com/forums/f116...-trans-115292/
Old Jul 19, 2007 | 07:33 AM
eric-the-red's Avatar
If you have an electronic speedo then a bad speed sensor could cause all those problems. The transmissions are electronically controlled, if the speed sensor is off then the trans will be changing gears constantly. That would also cause the rpm to change.
Old Jul 19, 2007 | 08:50 AM
colsoncj's Avatar
I was wondering about that... my original thought was the processing of the speed sensor signal in the ECU, if faulty, could do the same.... didnt think about the sensor itself (crap in = crap out)... however i would think the ECU would just go into "limp" mode with a faulty sensor, but I may be wrong (wont be the first or the last)
Old Jul 20, 2007 | 08:14 PM
meagadam's Avatar
thanks guys i talked to a friend of mine at aamco transmissions and he had also said it most likely would be something with the speed sensor either its bad ,theres a short or just a loose connection couse the tranny is computerized and the sensor is reading the mph rong witch couses the tranny to try and follow .thanks again you guys rock
live4soccer7
May 11, 2016 06:52 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Rickstwowheels
Sep 29, 2015 02:23 PM
83
Sep 27, 2015 04:13 PM
