Help Id This Diff
Old Jul 18, 2007 | 12:08 PM
Rocketman's Avatar
Help Id This Diff
Can anyone positively ID this as an 8" Detroit?? If not what is it??? Who ever installed it, mauled the housing in a vice!! Runs fine though on the rig it came out of. WAS in an 88 2WD PU, going into my 4WD 86 PU
Old Jul 18, 2007 | 12:27 PM
anthony1's Avatar
You might wanna make sure it's an 8" ring gear and not a 7.5".
Old Jul 18, 2007 | 01:13 PM
881stGenRunner's Avatar
X2...
Old Jul 18, 2007 | 05:18 PM
MudHippy's Avatar
I believe those marks are indicative of the ring gear bolts failing. Allowing the ring to be driven into the carrier creating those gouges. Notice the spacing. My best guess anyway. Or they were milled there to aid oil flow.
It's definetely not a stock carrier, whether a 7.5" or 8". You'll find out when you try to fit your 4wd axles in it.
Old Jul 18, 2007 | 05:26 PM
HAVOC's Avatar
It looks to me like the pinion is contacting the carrier.
Old Jul 18, 2007 | 05:47 PM
Big_Denny's Avatar
they do that to keep the weight down and balance the gears
Old Jul 18, 2007 | 07:13 PM
Rocketman's Avatar
Regardless of how the marks got there, the axle it was in ran and sounded fine. YES, it is an 8" BTW. Still no one has ID'd the locker?
EDIT: Just got an ID. It is a Detroit Truetrac N61610
Old Jul 18, 2007 | 10:17 PM
drew303's Avatar
Never heard of that.
Looks like the pinion rubbing on the carrier. I see some gear paint on there so someone may have known what they were doing... but that Truetrac definetly doesnt come with those markings on it =) I know I installed one.
Old Jul 19, 2007 | 04:21 AM
Yoda's Avatar
X2
We had those marks from the pinion hitting the carrier. The crush sleave was loosened up. Tightened it. bearings failed later that year
Old Jul 19, 2007 | 07:18 AM
drew303's Avatar
Originally Posted by Yoda
X2
Time for a solid spacer =p
Old Jul 19, 2007 | 10:31 AM
DeathCougar's Avatar
This info is 100% wrong. The pinion bearing are worn on the diff, causing it to move towards the carrier.
live4soccer7
May 11, 2016 06:52 PM
Badlander
Oct 10, 2015 08:05 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
