OEM or aftermaket Cold start Injector?
Old Jul 23, 2007 | 06:51 AM
co4rnr's Avatar
Dealer for 271.89 or Bocsh for 142.48? This would be for my 87 22re.
Old Jul 23, 2007 | 11:23 AM
co4rnr's Avatar
bump.
Old Jul 23, 2007 | 02:16 PM
dcg9381's Avatar
Neither. Send me $100 and I'll get you a cold start injector that's been cleaned, flow tested, and comes with new rubber.
Course, I'll be using an $5 injector that I've got sitting around and sending it to witchhunter.com for cleaning, balancing, flow testing and new rubber.. :-)
Old Jul 23, 2007 | 06:28 PM
84sr5yoty's Avatar
Have you confirmed that the cold start injector is indeed bad? They rarely ever go bad.
Old Jul 24, 2007 | 05:11 AM
co4rnr's Avatar
I don't know if it is bad or not, I just have a hunch. I have a weird idle and I tried replacing just about everything that I thouhgt could make a difference. I also have a hard time starting it when it is cold. It takes longer than usual to crank it.
Old Jul 24, 2007 | 05:56 AM
dcg9381's Avatar
The FSM has a diagnostic procedure that you might check out for testing the components. If you really think it's that injector, you can have it cleaned and tested at the above mentioned vendor for about $25.
Old Jul 24, 2007 | 03:09 PM
84sr5yoty's Avatar
Yeah, cold start injectors usually get dirty only although it would be possible for the pintle to be stuck open a little in an extreme situation. When I had my injectors cleaned, they guy said he could clean cold start injector for only $10 extra. My cold start injector was 32% plugged.
Ohm out the cold start injector. If it ohms out fine, just send it out for a cleaning.
Regarding your excessive cold starting issue, 99% of the time it's the cold start injector time switch that goes bad and causes that problem.
Old Jul 25, 2007 | 02:35 PM
co4rnr's Avatar
how do you change out the cold start switch?
bigjstang
Jun 2, 2025 03:56 PM
BushPig
Oct 29, 2022 06:26 AM
steve miller
Oct 10, 2015 01:40 AM
raiderhawks00
Jul 8, 2015 06:23 PM
karbin
Jul 5, 2015 11:37 PM
