a sudden loss of power
Old Jul 16, 2007 | 11:16 PM
Toyota_Pilot's Avatar
I drove over a friends house and everything was fine, i jump back in the truck and i had no power, it felt like i was towing something. it idels fine, but if i take it past a quarter throttle it bogs down.
I've replaced the coil, cap, rotor, plugs and fuel filter. and the cat isnt blocked. and now im all out of ideas. the only thing i did diffrent was i fill about half tank with AMPM gas.
Does anyone know what migh have happened?
Old Jul 16, 2007 | 11:20 PM
locked stock 84's Avatar
AMPM = ammoco premium?
Did you get a check eng light?
Old Jul 17, 2007 | 04:10 AM
thook's Avatar
It's Arco gasoline. People have had mixed results with that company and it's product (same could be said for others). So, it's possible that it's bad gasoline. Try an additive like Seafoam, Chemtool, etc. and see if it helps. Then, on the next fill up, use a different brand....like the one you're used to.
Old Jul 17, 2007 | 09:21 PM
gametom's Avatar
if you have the clutch in will it rev?
because this is what mine is doing if i run 2nd and 3rd gear to 5k it normally clears up. thus far i have tried the tps, vmaf, egr, cat, fuel filter, and the startup temp sensor. i took it to my local dealer for the 50n recall so i had them look in to it they where unsure thought a tune up and new fuel injectors whould fix it. i did a tune up about 15k before this started and havent had a chance to try fuel injectors.
Good luck.
Old Jul 17, 2007 | 11:54 PM
my thought it was bad gas after that so i filled it up with shell v power 92 oct. and a lucas fuel injector cleaner, no luck. and ive taken it to a mechanic who said to take it somewhere else cuz he didnt know what was wrong. Also theres no check engine light so the code reader i had acess o showed nothing
Old Jul 17, 2007 | 11:59 PM
run a compression test, then post em up.
Old Jul 18, 2007 | 10:20 AM
thook's Avatar
Sounds like you lost a connection (i.e. electrical) somewhere.
Old Jul 18, 2007 | 02:51 PM
Tim_Snapple76's Avatar
stealership is trying to break it off in your behind by replacing the injectors.... mucho dinero my friend. send them to cruizn performance if they're worth sending. mine is losing power right now, i too have the 3.0, but my exhaust is original and i have 241k miles on it so... yea. good luck, keep us posted.
Old Jul 18, 2007 | 03:28 PM
im going to check the cyliner compression tonight, but it feels like its not getting enough air, toda i took the tubing off and didnt find anything like a forign body in the intake or manifold. Im thinking this is a computer problem more then a mechanical problem
Old Jul 20, 2007 | 11:50 PM
ok so i took it into a mechanic. they charged me 165 bucks to tell me i have a bad ECU, I took it out of the truck and put it in another truck. Made thee other truck run better. Other then the compression what can i check?
Sleaker
Aug 26, 2020 06:03 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Tacoma1313
Aug 17, 2015 05:44 PM
gmonnie123
Jul 26, 2015 02:44 PM
PlayAwhile
Jul 20, 2015 11:36 AM
