Driver's side switches don't work??
Old Jul 20, 2007 | 07:45 AM
whitetaco02's Avatar
I have an 88 4runner with power windows/locks, etc..
I tried to roll my window down today and I have no power to either switch. The switch on the passenger side does not work but I can normally roll it down with the driver's side switch. Now I can't and I have no power to the door lock switch and the window switches. I was told to reset the circuit breakers that are in the driver's side kick panel but is there anything else I need to look for? Any particular fuse and any advice on resetting the circuit breaker? I have never had to do it before and really don't know what to look for. I was told to use a test let to reset it. Is that ok? thanks so much and look forward to hearing your responses.
Side note: I did take the door panel off the other day because I replace the runners in both doors but I did not disconnect anything and it all worked perfect afterwards. thanks
Old Jul 20, 2007 | 08:51 AM
4Crawler's Avatar
See if the switches have pulled apart:
- http://www.4crawler.com/4x4/CheapTri...l#WindowSwitch
Also, the window switches are typically connections to ground, so you generally won't see 12V at them. You likely have relays for the window motors, check those too.
Old Jul 20, 2007 | 12:56 PM
that is exactly what happened. they pulled apart and are now nice and tight and working again. thanks for the reply.
gillesdetrail
Nov 19, 2019 12:56 PM
Ichneumon
Sep 27, 2015 04:21 PM
Jeffrey Yao
18
Jun 27, 2002 01:33 PM
