Balljoint spacer and wheel spacing
I'm running some chevy 16" rims and I currently need a 1/4" wheel spacer in the front to clear steering and barely clear as it is.
If I install the bj spacers, sounds like I am definately going to need a wider wheel spacer. Does that sound right?
thanks,
thanks,
I definitely needed a wheel spacer. Looks like 1" spacer would have done it, but I had a 1.5" spacer already.
Strangely enough, The instructions say to place some metal under the upper a-arm to keep it lifted a bit. I could not get everything back together like that. I removed the stuff I jammed in there and I easily got my balljoint into the spacer.
terminator
07-27-2015 07:13 PM
FS[SouthCent]: TX Third Gen UCA and LCA low miles Taco
KyleT
07-21-2015 07:54 PM
