swap 22re w/ 3vze ?
Old Jul 22, 2007 | 01:47 AM
nytro48's Avatar
Unhappy swap 22re w/ 3vze ?
how much trouble would it be to swap out an 22re for a 3vze? my 4 banger quit on me, but it's in better shape than my v6 wich is not in that bad of shape itself.(4runners). the 4cyl. is an 86 and the v6 is 89 and runs like a champ even w/197,000 miles on it. should I even bother?
Old Jul 22, 2007 | 01:56 AM
Elton's Avatar
welcome to yotatech... cheaper/easier to rebuild the 22re
Old Jul 22, 2007 | 02:06 AM
nytro48's Avatar
has anyone ever used this site www.toyotacarpart.com cheapest engines I could find. I found some threads for swapping out the engines and trannys and it sounds like to much trouble. Gonna buy or rebuild the 22re.
Old Jul 22, 2007 | 02:17 AM
Elton's Avatar
www.engnbldr.com has the best parts
Old Jul 22, 2007 | 04:17 AM
Tim_Snapple76's Avatar
rebuild, or buy a new 22re. You'll be glad you did. 22re will last you longer if you take care of it. Its also alot better on aftermarket parts, easier to get more % of hp out of it than the 3 slow.
Old Jul 22, 2007 | 06:09 AM
YotaJunky's Avatar
You'll need to swap out the tranny if you go ahead with the 4 to 6cyl swap. I would stick with the 22RE and either fix it or drop in another one. I've had both engines and the 4cyl is by far much easier to work on.
Troy
Old Jul 22, 2007 | 09:44 AM
thook's Avatar
22RE is better on mileage and much easier to work on.
Old Jul 22, 2007 | 12:20 PM
RustBucket's Avatar
The answer you will get here is: no.
Old Jul 22, 2007 | 12:30 PM
nytro48's Avatar
thanks for all you input, sounds like i'm gonna save myself a headache and fix or buy another 22re...c-ya!
MadMax48
Mar 3, 2020 10:33 AM
Hugh_Mann
Sep 16, 2015 03:59 AM
LotOMiles
Sep 14, 2015 11:45 PM
