spray on bedliner questions
Old Jul 18, 2007 | 05:15 PM
HAVOC's Avatar
If I spray this on the floor of my cab (after the rust is fixed), can I still install my carpet without worry about heat or moisture buildup under the carpet.
Will I have to remove the factory sound deadening from the floor or just spray on top of it?
Thanks
Old Jul 18, 2007 | 06:22 PM
Jay351's Avatar
yes you would have to remove all the stuff so the bedliner can grab onto bare metal.
you wouldnt have to worry about moisture unless you spilled or got water in the cab.
Old Jul 18, 2007 | 06:52 PM
justinking060310's Avatar
i agree with the above post - you dont have to be all the way to bare metal though. get down to clean paint or bare metal and clean with acetone or mineral spirits right before you apply it.
I have done this with great success and would higly recommend it . I used herculiner, what are you using?
I find that an angled die grinder works excellent with 3m scothbright pads if you have a compressor available.
Kat
Old Jul 18, 2007 | 08:28 PM
dropzone's Avatar
Fossilized
Go with the Herculiner. It is a little more money, but I feel it does a better job than the Duraliner that I recently used. As mentioned before, surface prep is the keep to a good bonding.
Old Jul 19, 2007 | 01:05 AM
premirrider's Avatar
how does the hurculiner hold up, I mean does it chip, or wear? Im thinking about hurculining my bed, and bed rails.
Old Jul 19, 2007 | 02:37 AM
HAVOC's Avatar
I need to have two small rust holes fixed first.
Old Jul 19, 2007 | 12:11 PM
duck's Avatar
My buddy used Herculiner on the bed of his truck with poor results. I didn't see him do it so I can't vouch for his surface preparation but the liner was chipping and peeling off in large quantities within a year.
chukarhunt
Dec 8, 2019 11:39 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
