polyurethane bushings & SAS
Old Jul 22, 2007 | 04:41 PM
HAVOC's Avatar
Question polyurethane bushings & SAS
I bought Energy Suspensions 8.18101 "master kit" (a while ago) for my truck. I'd like to do a SAS, and get rear springs to lift the rear. Are the only useful parts now, the cab bushings? Can I hope to sell this kit without the cab bushings? I don't think I could even use the tie-rod boots, huh?
Do SAS kits have urethane bushings in the leafs, or do you have to specify that?
Old Jul 22, 2007 | 08:10 PM
MudHippy's Avatar
Energy Suspension
8.18101
1989-95 HYPER-FLEX SYSTEM Complete Master Bushing Set Includes: Front control arm bushings, rear spring and shackle bushings, front sway bar bushings, body mounts, tie rod end boots.
If that's the set your talkin', then they should all be usable, right?
Did you mean?
8.18102
1979-85 HYPER-FLEX SYSTEM Complete Master Bushing Set Includes: Front and rear spring and shackle bushings, front sway bar bushings, torque arm bushings, body mounts, tie rod end boots.
If so, I would think you could go ahead and use the rear spring and shackle bushings. I don't think the tie rod boots are any different either, not 100% sure on it though.
Sure, I don't see why you couldn't sell the kit minus the cab bushings. All their bushings are available for sale individaully on SummitRacing.com. I still need to get some cab mount bushings and tie rod end boots from them here soon. DowneyOff-Road.com has some too.
Some SAS kits probably do, I know Downey's springs do.
Old Jul 23, 2007 | 02:52 AM
HAVOC's Avatar
I have the set for the 89-95 trucks: #8.18101
Old Jul 23, 2007 | 05:53 AM
waskillywabbit's Avatar
All of our SAS kits and rear lift kits come with new bushings.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
