Went mudding... Now idiot lights are on!
Old Jul 25, 2007 | 08:50 PM
Kiff's Avatar
I took my 91 4runner into the mudpit and on some gravel roads the other day, played around a little, nothing too bad, a couple potholes I wasn't able to miss, but on the way out I noticed the A/T oil temp, batt, and park light were all on, aswell my DTRL don't work now either. I am guessing I've blown a fuse or a wire has come undone, as this all happened together...
The A/T fluid is just fine, parking brake is not on, I haven't had a chance to fully check out the charging system, but the truck runs with the batt unconnected, and his driven fine for 100k or so on the way back from the lake.
Anyone have any ideas?
Old Jul 25, 2007 | 08:56 PM
MRecio's Avatar
All those exact same lights came on when i snapped my altenator belt...
I would check to see if something like that or any damage to the alternator has occured.. i
Old Jul 26, 2007 | 07:27 AM
MMA_Alex's Avatar
i dont have the a/t temp light as i've got a m/t, but the batt & e-brake lights mean the alt isnt charging properly. check the voltage and make sure its around 14 v while running, and 12.something while the engine is off. perhaps the voltage regulator kicked the bucket? if it still runs with the battery disconnected then it must be working to some degree atleast
Old Jul 26, 2007 | 07:37 AM
CJM's Avatar
CJM
The alt is probably very dirty, clean it with some electric parts cleaner and wash down the enginebay.
Old Jul 26, 2007 | 09:58 AM
rdlsz24's Avatar
As soon as I read that all your idiot lights are on I thought alternator.
Rob
Old Jul 26, 2007 | 02:11 PM
ovrrdrive's Avatar
There'a a plug on the alternator that comes out sometimes that will account for the charge and brake lights, but I don't know about the rest.
Old Jul 26, 2007 | 05:40 PM
89red4x4yota's Avatar
i say give it a good washing and see then...alt prob clogged with mud
Old Jul 27, 2007 | 08:19 AM
brandyn85's Avatar
dont spray the alternator with water... thats how i killed one of mine, if anything spray with some parts cleaner like mentioned above and let it dry out before trying to start it. on the 3.0 toyota alternators they do not like water so much im on my 3rd one in about 3 months
Old Jul 27, 2007 | 09:40 AM
mehret's Avatar
I don't think there are any standard alternators that like water.
Anyway, alternator's your problem.
Old Jul 27, 2007 | 10:31 AM
04 Rocko Taco's Avatar
I would think spraying the alt with water would be fine. CLEAN water, and let it dry before you crank it. Water, DRY, Electrical parts cleaner (also a water displacer) and then crank her up.... might want to make sure your batt is good and charged also, since your having Alt problems...
Old Jul 27, 2007 | 12:02 PM
Kiff's Avatar
A new alt fixed the problem, I was planning on doing the GM upgrade in the near future anyways.
Old Jul 27, 2007 | 01:15 PM
Tim_Snapple76's Avatar
good to hear that you got it fixed.
ashersullivan88yota
Jan 18, 2022 05:37 PM
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
