lift kit
Old Jul 25, 2007 | 01:39 PM
run4her's Avatar
lift kit
I need the front lift for a 1990 ifs 4runner. anybody have one or know someone who does?
Old Jul 25, 2007 | 01:45 PM
slosurfer's Avatar
try putting something like "lift kit" in the search feature
or "ifs lift" "suspension lift" etc...
Edit: I saw you have bj spacers already. Try posting in the wanted section.
Old Jul 25, 2007 | 03:52 PM
norcalsvx's Avatar
how high you wanna go
Old Jul 25, 2007 | 03:58 PM
run4her's Avatar
5 or 6 hundred.
Old Jul 25, 2007 | 04:09 PM
Kaleb's Avatar
Originally Posted by run4her
5 or 6 hundred.
He meant how high do you want to lift your truck?
Old Jul 25, 2007 | 05:03 PM
run4her's Avatar
sorry 4inches. i already have bj spacers, l/c coils and 35"s but they rubb on the front a little.
Old Jul 25, 2007 | 05:09 PM
Tortuginator's Avatar
I am a firm follower of the ways of "Craig's List!" Give it a try! You can find almost anything you want (or don't want{or never thought you wanted.})
Give it a try!!
Old Jul 25, 2007 | 08:55 PM
olharleyman's Avatar
I had the same issue with rubbung when I put my 35's on and I have a 4" suspenion lift (PRO COMP STAGE II) and still had to trim the pinch welds to make the tires work without rubbing. If I were you I would try the trimming the pinch welds thing first then if you need a lift still you have it out of the way and will be ready to roll.
Old Jul 25, 2007 | 08:59 PM
4Crawler's Avatar
A mild body lift is one option:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Or trimming/hammering back the pinch weld and firewall where the front tires rub.
Old Jul 26, 2007 | 08:29 AM
run4her's Avatar
mine rubbs on a steering part not the body. i think its the pitman arm or something.
Old Jul 26, 2007 | 08:33 AM
4Crawler's Avatar
For that, the best option would be a small wheel spacer or a set of wheels with less backspacing than what you have now.
Old Jul 26, 2007 | 08:37 AM
run4her's Avatar
well i think if i fot like a 4 inch lift it would not do that anymore plus the @$$ is a little higher anyways and i dont want to crank the tortions any further.
Old Jul 26, 2007 | 08:42 AM
4Crawler's Avatar
Yes, a 4" bracket lift will raise the frame up above the tires, moving the point of contact away from the largest diamter of the tire. Many of the 4" lift kits do have a maximum backspacing requirement of around 3.5"-3.75" in order to keep the tires off of the modified steering/suspension components, so keep that in mind as well.
Old Jul 26, 2007 | 08:44 AM
run4her's Avatar
k thanks.
Old Jul 26, 2007 | 09:14 AM
chimmike's Avatar
check the classifieds, I'm selling an almost complete lift.
Sep 4, 2015 09:27 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
coffey50
Jul 28, 2015 10:55 AM
kirkrunner
Jul 27, 2015 07:59 PM
