Deep Water.....
Old Jul 18, 2007 | 11:02 AM
keithguts's Avatar
Deep Water.....
Just a question. I have a stock 95 4runner with 31" tires. My ? is, how deep can I drive this rig in water without doing any harm?
Old Jul 18, 2007 | 11:04 AM
gilby4runner's Avatar
under the air box
*if you dont have the breather extension (diff) just check the fluid if you ever have water over the diffs
Old Jul 18, 2007 | 11:05 AM
Kaleb's Avatar
Anything close to the bottom of your headlights. To be more exact, keep below your intake.
Old Jul 18, 2007 | 11:08 AM
SoCalWheeler71's Avatar
the rear axle breather is right on the housing, not sure about the front (I've heard the front has a hose up to the engine comp but not sure if that is factory) and the auto trans breather is low too. So mid axle is safe unless you extend the breathers.
Old Jul 18, 2007 | 11:12 AM
MudHippy's Avatar
The other concern is the EGR Valve. It isn't sealed well against sucking in water, which can make it temporarily malfunction. It rides a little higher than the air box, but don't be too suprised if you splash some on it and your engine starts runnin' bad. Happened to me a couple times, no biggy, fixes itself.
Old Jul 18, 2007 | 11:16 AM
keithguts's Avatar
[QUOTE=gilby4runner;50575422]under the air box
If I run this deep, I'll have water in my rig. But I do no now of my limits.
Old Jul 18, 2007 | 12:11 PM
amgraham's Avatar
I've run to the bottom of my headlights and have not gotten water in my rig. Do extend the diff breathers to be sure as they are ridiculously low.
Old Jul 18, 2007 | 12:15 PM
keithguts's Avatar
Not quite sure of how to do this, or even what to look for. Any pics?
Thanks...........
Old Jul 18, 2007 | 12:20 PM
MudHippy's Avatar
http://www.marlincrawler.com/htm/axles.htm
LittleUgly
15
Jan 2, 2020 01:30 PM
RDubya
Feb 10, 2017 04:46 PM
highonpottery
Nov 22, 2015 03:57 PM
kawazx636
Sep 29, 2015 08:22 AM
Obmi
Sep 24, 2015 08:10 AM
