- Who sells throttle body parts?
- No Reverse unless in 4 Lo
- 91 4Runner Tailgate Window Unknown Gremlin
- Need the carburetor gurus!
- Overdrive Blues
- shock length and flex
- For those who manual swapped a 22RE 4x4...
- Help me for the love of god!!!!
- No blinkers/wipers
- Engine Swaps
- 22RE High Idle
- 94 4runner 3.0 power steering issues
- Adjustable Upper rear control arms or links
- 2nd gen 2 door automatic mid window mod or weather proofing?
- 1990 pickup tailgate drop in swap
- Changing starter 3vze with headers ?
- head gasket not blown, melted?
- TPS don't jive with body
- total chaos tire fitment
- Temp gauge
- Engine power loss/chugging until restart?
- 3vze torque problem
- Power steering pulley?
- Need some help
- Rear door getting stuck, help!
- Drivers side rear window won't roll up. 94 4runner
- 22re cuts out
- Need Help: 22r overheating
- Help Diagnosing Random Stall
- 88 3vze: need diameter and pitch of threaded holes on the side of the head
- Turbocharging A Stock 22re?
- Help with crank and rods
- Went to change cluster to LED, preformed open heart surgery. fun pic + help!
- Rear Window - Rolls down on its own!!
- 1987 Toyota Pickup A/C stumped.
- Lower control arm bushing
- coolant filter
- 88 toyota pickup 4x4 22re ignition by pass
- manifold collector bolt size 3.0
- Probably the craziest project I've ever undertaken....
- NEED HELP!!!!!!!!!! 91 pickup 3vzfe
- Fan Shroud Ordering Help!
- 94 pickup 22re sluggish bogging idle issues
- 1987 4Runner a Good Deal?
- No heat
- A/C condenser fan ghosts
- help me
- Zuk mod
- Troubleshooting my 1993 22re
- What should I do
- '94 Pickup Tailgate Latch Broken, how would one fix?
- 1991 Pickup - 3VZE fuel line / filter stripped out. How to replace?
- Brake lights staying on/stuck
- Is it legal to have the spare wheel in the back?
- Zuk mod help
- 1st Gen 4runner Seats
- CODE issue. SOS HELP!
- 1988 Toyota 4Runner
- Block antifreeze drain plugs 22re
- Transmission fluid, direction of flow?
- 91 Toyota pickup ignition switch, key will not turn!!??
- LCA replacement
- 22RE Leaky Water Pump Gasket
- Idle Air Control Valve Needed for '87 22re
- 22re electrical issue leaves me stranded in the Sierra
- Power steering vacuum control valve
- 94 pickup fuel lines
- 91 22RE Should my Oil Pressure Warning light come on when disconnected?
- Extremely low Idle
- Am I in danger of overheating my Toyota pickup?
- 94 yota 4x4 Alternator
- Looking for a '86 owner's manual PDF
- questions on buzzer and rear window function
- Toyota 3.0 extremely sluggush
- Auto hub issue
- 87 4Runner Rough Idle/Misfire issues
- Leaking Rear Tranny Seal and Top Tranny Gasket
- 91 4Runner
- One dash light doesnt work sometimes
- Overflow issues on 93 SR5
- Do i need to put these back on?
- 22re electrical no spark/ no cel /won't start
- 1988 pickup oil pressure gauge wiring HELP!
- 90 4Runner starter stuck on. Now won't start
- long block
- Water pump issues and repairs
- Gas gauge not working
- Rear diff alignment
- Upper shock nut PIA POS pics
- Questions about installing a new 3.0
- 1994 22re no start. Help!
- Rough idle mystery
- Radiator filler neck
- Need help Oil Leak
- 7x6 retrofit mini h1
- Need help 1986 truck air conditioner recharge
- EGR Cooler Plate Torque Values?
- 88 4runner 3.0 jolting randomly when accelerating
- 1987 4runner kickdown cable
- Write-up: Converting forward shift transfer case to a top shift for crawl box
- 87 4Runner unidentifiable engine noise
- 86 Pickup 4x4 seat upgrade
- Changed transmissions now reverse lights wont work
- Rear brake line routing
- 1987 toyota 22r weber throttle linkage
- Please help!
- 22r leaking
- 3vze help
- factory A/C wiring
- help with 1986 pickup
- Lspv
- Low fuel pressure
- code 26
- one tire closer than the other
- Do I bother fixing it? 1993 3vz-E 4x4
- ARB Locker Crack..
- ENGINE TROUBLE 3vze please help :(
- 1992 toyota 22re
- Dash lights and interior lights wont work
- aftermarket seat covers for '85 front and REAR seats?
- Leaking extention housing seal
- 94 yota 4x4 cranking issues
- Icentropy's $400 4runner build
- 94' Pickup ZUK Mod - What Springs?
- Here come the bearings....
- Need new radiator for 1994 V6 4wd. Any recommendations?
- 1993 4Runner stalls at idle
- '86 Turbo Fuel Pump Replacement Question
- Cold Start Issues
- 88 Pickup Transmission Swap
- 93 runner build
- speedometer 'freaking out'
- '94 3.0 Pickup Clutch Pedal Sticking
- rear bump stops for zuk mod, don't have them!
- 1991 Truck 3vze Cooling Fan Compatibility
- New AC Questions (Not the same old ones)
- back of cab body plugs (1991 sr5)
- 87 22r rebuild issue
- 1st gen runner trailer wire routing
- 1988 Toyota fuel sending unit
- 2nd Gen 4Runner buckets seats. Are they all the same?
- 92-95 Pickup Bumper/Valance Varations
- 22rte to 22re / injectors not firing
- 94 sr5 code 14
- Consistently losing valve clearance on one valve
- 88 3vze pickup starts then dies
- Rear window problem
- 92 runner donner parts truck for a 88 runner
- No Key Mod Rear Window on a 2nd Gen
- SAS Front drive shaft opinions needed
- No power to fuel pump
- 91 Pickup DLX - Clutch Kit Advice?
- Identify this 3vze connector...
- Help me determine my gear ratios
- 87 4Runner AC Compressor Oil Capacity
- Interior Panels
- fuel pump knocking replaced and now guess what
- A/C Compressor Not Kicking In
- Old Man Emu leaf springs/shackle on 91 truck?
- 22RE low idle / hard start
- Damaged crank/pulley -- is it ok?
- 94 runs without fuel pump on?
- 94 toyota pickup will crank but not start
- 93 pickup brake issues
- Distributor Cap wearing prematurely
- Overdrive on or off?
- 4wd Engagement Help 1993 3.0 5 Speed SR5
- 22re Overheats when climbing hills
- A340h acting up
- AC pressure switch fit?
- 94 22re multiple codes with misfire
- 3" suspension lift
- '89 22re barely running
- only getting 9mpg
- Timing chain replacement woes
- Flowrate needed for Weber carb fuel pump
- HELP! Cannot identify part that is leaking
- 1989 IFS Hi-Steer Conversion
- Power antenna broken
- Cruise control
- Need tips on removal of broken bolt
- Engine Fuse Box Missing Wire
- Leafspring pad replacements?
- What to know about 87 pickups
- Start problems
- Fusible link ?
- 96 4runner won't start.
- Rear tires lean in at the top
- Supra afm swap help needed!!!
- 1993 Toyota Pickup Bumper and Winch
- 1991 toyota pickup. BRAKE! light on dash stays on
- 3vze head gaskets really a problem?
- How to remove No. 1 coolant bypass pipe on 1990 3vze?
- Need help with part name
- Attn: 22RE lovers - need some advice.
- 1991 truck 3VZE Help with diagnosis (Results of tests)
- Carrier Bearing Nut Part Number?
- timing mark moving
- Need help on 88 4runner no idle stalls
- Idle issues
- Just bought a 1993 3VZ-E doc 4x4. What you think?
- Does the 1995 pick-up w/22re have T100 evaporator?
- 94 4x4 pick up condensate problem with clear drain
- Before I start tearing it up
- Water Leaking Behind Dashboard
- Code 25 problems
- Fan Clutch - warming w/AC on (94 SR5)
- Oil and gas in spark plug well. What are possible causes?
- 93 22re takes 5+ cranks to start
- Replaced KS wire, now she won't start.
- Torsion Bar Creaking/Popping at the Adjusters
- Temp sensor
- FIPG on rear axle?
- 91 4Runner - Random click / clacking sounds at low speed
- Surging idle
- Manual Transmission Radiator Source
- Changing Front Brake Rotors 2WD
- Non-A/C P/S pump bracket?
- T100 Automatic Tach swap?
- Electrical (earth?) problem 1994 22r
- 3.0 In Need of More Power.
- which ome kit for a 90 4wd pickup
- Is there a DIY way to find the source of an oil leak?
- Newbie
- Very odd Misfire
- Hard start and code 11 think its cold start problem
- Update on Second Guess
- need help identifying these broken parts
- 87 4runner ZUK mod question
- Air Conditioning Retrofit
- Lindsay's Long Leg Seat Mod
- Help 3.0 not running after new plugs
- A fine new addition
- Different a/c hose sizes ?
- Need some advice about my 22RE
- After market dip stick
- Toyota IFS Knuckle seal HELP
- Has anyone used this vendor or parts
- fuel injector connector splice
- COR permanent "SAFE" fix
- inspection plate cover
- 22RE Intermittent CEL and Truck Surges During Acceleration
- Flooding in a 22re
- 1991 toyota 4runner 3.0L timing belt/new injectors/vale job,service
- 88 22re pickup turns off
- 3.4 Clutch on 1992 3.0 V6
- 88 pickup problems..
- 89 3VZ-E Rebuild/Shop manual
- 92 Rear gears whining
- 86 22r problems
