Engine Fuse Box Missing Wire
Old Jun 26, 2015 | 01:00 AM
Uncle D's Avatar
I've done some work with my motor and am currently in the works of doing a sort of engine wire tuck. I don't quite recall but I'm wondering if this device that use to mount to the bottom of my intake manifold is what leads to the missing wire that the screwdriver is pointing too.
Old Jun 26, 2015 | 03:22 PM
Uncle D's Avatar
Nobody?
Old Jun 26, 2015 | 03:51 PM
mct75's Avatar
That's the cold mixture heater, it's not required. Just helps with starting/idling when the engine is cold.
Old Jun 27, 2015 | 01:22 AM
Uncle D's Avatar
Ok thanks. Im more interested in knowing if its what was pinned to thr spot i have pointed out with screwdriver.
Old Jun 27, 2015 | 04:24 AM
wyoming9's Avatar
Red face
Are you 100% sure there needs to be a wire in there??
Not all these plugs use all the pins.
What do you have that might not be working??
Just what year are you toying with??
Old Jun 27, 2015 | 09:23 AM
Uncle D's Avatar
Its a 86, 22r. Im pretty certain that half of the wire was pinned to there i just am not sure (even though in plugs into it) that that air mixture heater is the correct thing to be plugged into it.
And at this point im not sure what worms or doesnt.ive made this wiring part of the engine rebuild process so havent ran motor yet.
Old Jun 27, 2015 | 12:45 PM
wyoming9's Avatar
Red face
If that is a Black/ Yellow wire it does go to the CMH
With a green one conductor plug
Old Dec 14, 2015 | 06:11 AM
uncleblues's Avatar
black/yellow should go to the cmh relay
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
toyota32
Jul 6, 2015 05:42 PM
ptb12
Jul 5, 2015 01:49 PM
