- Rear brake drag
- leaking rear main seal!!!!!!!!!!!!!!!!!
- 3.slo to 3.4
- Installing new suspension
- Spare tire lift - part 1 complete, need HELP with part 2!
- 95 4runner running very rough
- Reseting CEL and Radio anti-theft on '92 T4R, need help.
- Decals on 95 4runner
- Trimming Lower Valance
- Fuse tap on e-locker wireing...
- 3.0 belt tightening
- Which bulbs to put in my "new" instrument cluster??
- My 87 4runner is leaking like a sieve
- Another 50N recall horror story..need help going to bat
- Check Engine light-ECU code coming up?
- need engine help with my 89 3vze
- need engine help- 89 3vze
- Where to get oil sending unit for 22re engine?
- Got my $12 camshaft!!! Looks real good, but now what?
- Need experienced advice about '90 runner, please.
- Any 3.0 experts in Nebraska?
- Emissions Question
- 92 toy engine swap 89 rebuild
- Exaust, What pipe size?
- Erratic coolant temp
- 91 4Runner
- my 88 truck with 03 tacoma wheels
- How to set v6 @ TDC with timming belt off?
- wiring schematic for 1991 4runner????
- screaching sound
- Another poor fuel mileage problem
- Add-A-Leaf instalation help needed!!!!!
- '94 Pick up - Dash/Center Console Dissasembly
- wheel studs
- 2002 4Runner Tire Recommendation
- What kind of shocks do i get?
- Custom Bumper wish list
- power steering air valve
- Rear end question
- bad idler arm?
- Running Wires from Bed to cab...(Searched)
- high cold start idle on '93 3.0 4runner
- Proper timing question
- Going in for the recall and a bunch of other work tomorrow
- Where to get 3.0L headers
- All pro off road coil springs
- LED Parking Light/Turn Signal Mod Complete
- Idle speed ?'s
- Good idler arms
- God help me I broke a fuel line!!!
- Oil Cooler O-Ring leaking
- Anyone bought an engine from Orient Engine
- Pickup Topper
- 1994 4runner value
- '92 4runner, motor transplant
- Need help finding: Engine Coolant Temperature Sensor
- Issue with my '94 Pickup
- Power Steering, bleeding?
- Tranny/transfer schematics?????
- Engine Surges on '88 P/U 22RE when a/c is on and brakes are applied at a stop (Idle)
- Vacuum Hose Routing
- '88 on eBay looks good. Better Hurry.
- When does the 3.0 stop making power?
- help: noise coming from the front of the truck
- U-Bolt?
- Lining came off brake shoe!
- p/u seat
- 91 4runner rear suspension question
- Any advice for purchase and build up
- 91' V6, starter replaced, only "Clicks"
- 3vze top end rebuild (head bolts)
- 1" BL with 33's finally hits home...
- Rebuild '94 pickup transmission?
- Parking Light Fuse Location on 93
- Help with ticking from my 90 4runner
- Need help identifying 22r Mikuni camshaft
- Ooops.....I think I just won the wrong camshaft!
- 2nd Gen Runner Rear Wheel Well Options
- 4.10s to 4.30s Worth it?
- v6 Idling rough at 500 rpm
- Got a TJM brushguard...
- Lumpy idle question
- Door Buzzer...
- catalytic converter
- Found a 1st Gen
- why do i now have no power?
- 4x4 Front Locks, always on?
- 1994 p/u VIN locations?
- Safari snorkel intall
- Dome light dims every 6 secs when engine off
- code 12, what to do?
- Rear end wind like noise and a big jerk :)
- small block 350 help
- code 13 and code 14(ignition signal and rpm)
- accident
- clear cover for gauges ( need one )
- 89 Rear main seal replacement
- the 4runner is back in business!
- Will a Tacoma 2004 rear bumper fit on an 89
- fiberglass fenders: what tire size?
- 4:10 V.S. 4:88 pinion diameter
- Getting a 1st-gen soon
- What to watch for, 1st gen runner
- tach needle broken need help
- 87rnnr fuel tank relocation???
- Timing issue
- 4runner and small tires
- Auto motor bolt up to stick?
- Towing a Toy that is locked
- OEM Toyota Tokiko Factory Shocks
- Power Steering Problem
- Octane
- white face guages with tach?
- lights on dash wont go out
- Cupholder Mod for 87 Pickup?
- Aluminum Radiator?
- how much brake fluid?
- stumbling at start-up...3 cyl?
- V-6 3.0 ***
- head gasket removal?
- did the ISR mod and deckplate today
- Help with a 22R Carb Rebuild
- 22RE bogs on me.
- What about post 95 T100s
- blown head gasket? what if?
- Gas and clutch tip
- Coil or starter?
- Clutch Squeak
- T-bars, BJ spacer, and extended schakle
- Questions about oil pressure and oil pump replacement on 3VZE
- Strange problem with battery light
- fender flares
- revolving shackles w/ i.f.s
- Automatic Transmission problems
- Location of front differential fill plug
- shackel lift good or bad?
- What do I want to do next?
- Steering Gear Leaking
- what camper shell fits?
- my truck (pics)
- Manual 1994 4Runner
- Drivers side rear wheel locking up
- advice for replacing header pipe
- Bilstein Installed
- ADDED EXTENDED SCHAKLES this weekend
- Where to find oil pressure sending unit?
- PAIR system + Downey Headers
- Will a 93+ grill fit on a '90 4runner?
- CV Axles question
- shackles
- How to fit 35's on a stock 3rd Gen...
- HELP! 11mpg highway now :(
- Ground Stap / Prime Fuse Question!!!
- silverstar headlight bulbs
- "Diesel" / rattle sound at Idle 22RE (Searched)
- engine swap?
- I Need Help With a Shopping List
- Intake/Battery Swap 22re
- Engine will not return to correct idle without help
- detroit locker in a 5 speed
- Sway-Bar Disconnects for 2nd gen?
- rear window defrost repair
- My 91 truck runs too cold
- Another what's it worth question.
- Name your injector parts
- name those water-bypass parts
- Help before I sell it
- Parts transfer question
- 2nd gen vibration
- What do you think?
- Valve lash adjustment
- New electrical/starting problem
- Knock Sensor Help......
- 3 engine codes...ideas?
- Disabling DRL on 2nd Gen. 4runner
- Anyone ever put a MK2 supra LSD in a front 7.5 diff?
- IFS Front wheel bearing replacement
- 3.0 auto trans shifting weird
- Power Window Conversion
- Good Southern California Toyota Service Centers
- 22RE runs hot
- was for sale now a keeper
- Reliable source for rebuilt 3.0l motor & tranny?
- intake silencer removal
- Fender Bender, need help with a replacement part.
- Blower Motor Power Issue
- Fan Bracket Assembly Removal
- late 80's Yotas
- Cressida Engine For 250
- Engnbldr - Is this timing kit good?
- 90 4runner 22re coolent prob
- PLEASE HELP!! ENGINE RATTLING & LOSS OF POWER
- Pics of my truck before the pull
- These camshafts any good???
- 3VZE air filter
- pulling my 22r
- anyone have a toyota manual?
- Where is my coolant going?
- 95 Brembos - steering stabilizer - bilstien shocks
- 3.0L turbo diesel swap
- '95 Rear Widow Motor
- Looky what I just brought home
- grille guard
- trailer question!
- Show me some pics of 2nd gens with roof racks
- 1991 4Runner Tranny
- Front Axle seal leaking
- 2nd Gen OME install pics
- Hi-Lift Mount to yakima bars
- rebuilding engine... help me choose performance parts
- some pics of my rig
- Lexus V6 4cam
- 1st gen.22re clutch query
- question involving 4wd
- 3.0 swap compatibility issues?
- Spare tire lift swap
- 2nd Gen ARB Bumper on ebay
- $$$ for headers??
- Eratic Overdrive
- motor swap help needed asap
- head job? what exactly is that?
- Are cats directional?
- Leaky
- Need your advice: 3VZE rebuild or swap?
- Brakes Pulling To Passenger Side, 2nd gen 4runner
- Another Ebay find...
- 22re running like crap
- My Runner is on life support. Help
- Stuck / stripped 12 mm 3VZ head bolts....
- 89 4runner 22re question....Battery light
- simple exhaust question
- PS Pump Problems
- (2) 3.0 Questions: Timming, Worn Throttle Body springs
- Where's everybody getting their cylinder head work done now?
- Low Pro Bumpstops and BJ Spacers Shock Qs
- big ugly sees life again
- 3.0 performance head questions.
- Is this the place for all T100 topics?
- Noisy clutch bearing
- 16" wheels
- 1986 fuel filter location
- Gauge Suggestions
- Knocking 3.0. Need advice.
- Homemade headers, anybody tried?
- 22re questions
- Paper or plastic?
- Friend's 3.0 is dying
- Checking Manual Tranny Fluid
- Where can I get Grey 2nd Gen Floormats??
- fun with lighting
