Need help finding: Engine Coolant Temperature Sensor
Old Dec 27, 2005 | 02:40 PM
rpeAMP's Avatar
My 92's been throwing code 22 for the past several months (Engine Coolant Temperature Sensor). It's getting annoying now because it intermittantly blinks on and off, on when I hit the gas, and off when I let go at highway speeds.
Anyway, I'd like to locate this sensor and test it to see what's wrong with it. Can anyone help me locate it? I've looked at the FSM and it shows a picture of where to test it, but I can't seem to find what I'm looking for.
Old Dec 27, 2005 | 03:19 PM
Sequoia'd's Avatar
Bump... I'd like to know where it is also!
Old Dec 27, 2005 | 03:40 PM
Tragic Drive's Avatar
https://www.yotatech.com/forums/f116/name-those-water-bypass-parts-74247/.
It resides on the back of the block kinda under the manifold.. Ive looked for some better pics but this is the best I can come up with right now.
Old Dec 27, 2005 | 03:55 PM
callmej75's Avatar
The best I can do...
Old Dec 28, 2005 | 07:09 PM
rpeAMP's Avatar
Ok that gives me a general idea of where to begin looking.
The next problem is how I'm gonna get to it to investigate what the problem is.
I haven't noticed any performance issues since the CEL, and I'd rather have it just stop blinking at me off-and-on and just stay on.
Anyway, I guess I'll go to work trying to see what the issue is.
Thanks!
Old Dec 29, 2005 | 02:54 PM
hektikwon's Avatar
It may have a bad connection. When I redid my head gaskets I didn't get it hooked up good and got a code 22. Check inside the connector and make sure it's not pushed in too far.
Old Dec 29, 2005 | 03:17 PM
rpeAMP's Avatar
Ok so I just found out there's a few connectors back there.
I think it's the one on the top...is this correct? Hopefully the contacts just need cleaning or something like that.
Old Dec 29, 2005 | 08:03 PM
Manson's Avatar
If the connections are tight and clean you will have to test the resistance of the sensor when it is cold then monitor is as the engine warms up. Do this with the sensor unplugged. Usually you will find the sensor looses resistance at a certain temp then comes back into spec. You can also test the voltage of the sensor in the same manner and basically tests the same thing. Do this with the sensor plugged in. Good luck it is tight quarters back there.
Old Dec 29, 2005 | 10:14 PM
rpeAMP's Avatar
Wow I can barely move around back there...I may have to pull these heater hoses to get the job done.
If the voltage/resistance doesn't check out to factory specs, should I replace it myself or have someone else do it?? Is it hard to do it?
Charecter1
Nov 6, 2023 10:08 AM
sandyota
Feb 4, 2021 11:16 AM
Colington
Mar 8, 2020 09:51 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
wilbertd
Jul 6, 2015 07:39 AM
