22RE runs hot
Old Dec 16, 2005 | 03:56 AM
954x4's Avatar
22RE runs hot
1995 4x4 pickup 22re has started running hot. Enormous amount "steam" coming fron the exhaust. Any ideas? Could it be head gasket or intake gasket?
Old Dec 16, 2005 | 05:33 AM
PirateFins's Avatar
Well could be head gasket, intake gasket, or timming chain that broke thru water pump housing. Give us some more info. Does it steam all of the time? Does the exhaust smell like burning antifreeze? Does your engine oil look like a milkshake? Do you see black brown specks floating in the coolent? Have you done a compression test on the Cyl's or a leak down test on the cooling system? Let us know.
Old Dec 16, 2005 | 09:32 AM
954x4's Avatar
does not steam all the time... oil looks fine, but water gunk under oil cap( not sure if it is condensation).... fill radiator and crank engine ad water level is down conciderably in a few minutes with no visible leak.... no compression check yet... no radiator check
Old Dec 16, 2005 | 11:24 AM
Elton's Avatar
sounds like ur head gasket is blown
Old Dec 17, 2005 | 09:45 PM
surf4runner's Avatar
exactly how mine started to go bad. oil cap cream=new head gasket needed
compression check was negative. radiator leak test was positive.
Old Dec 30, 2005 | 08:39 PM
stevrock's Avatar
OH boy, I'm so excited.
Milky oil cap, had the rad flushed added stop leak, still milky cap.
I'm ready to cry.
Old Jun 13, 2009 | 07:53 AM
Teuf's Avatar
bite the bullet. I did, after all said and done replacing head (and head gasket) was not so bad, i could do again in 1 weekend
Old Jun 13, 2009 | 07:58 AM
toyota4x4907's Avatar
This thread was 4 years old before you posted
bigjstang
Jun 2, 2025 03:56 PM
Colington
Mar 8, 2020 09:51 AM
Avenged
Jul 9, 2015 07:55 AM
bryan34w
Jul 6, 2015 05:53 PM
HRDC0R19
Jul 5, 2015 06:43 PM
