1991 4Runner Tranny
some time I can get up in the mourning and the tranny will work fine all day then sometimes the tranny will go into od and then kick down to drive and other times it will not even try to go into over drive . The obvious is the rpm,s
well if yours is similar to a 94, it has a lockup converter, and for a while i thought my moms 94 was actually a 5spd because of that. how big of an RPM change are you seeing, its possible that the lockup converter might be causing problems, or it still could be the OD. i think the lockup converter caused about a 200-400 RPM change while the OD unlocked to drive caused about a 600 - 700 RPM change if i remember correctly....
Iceman4193
07-15-2015 04:48 PM
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
