HELP! 11mpg highway now :(
I have always had poor highway mileage with 33's and 5.29's on my 1990 4runner 3.0 5sp, usually about 15-16 overall. Recently it has dropped BIGTIME. I took a trip somewhere and basically drove 500mi in a day (100 in town, 400 fwy) and I calculated roughly 11mpg for the trip, 400 miles on a 34gallon fillup (i have 2 tanks). I usually tune it up every 75k or so, its probably been about 60k since the last cap/rotor/spark change, and the airfilter is a conical one that put in and doesn't look dirty at all. What else could have caused this? Its raining right now but when it stops i'm gonna go through and check everything, fuel leaks first, but what should I go to next? what would cause such a drastic drop in fuel efficiency? O2 hasn't been changed to my knowledge, about 205k on the dial now. Could it be that? EGR? thanks
Fuel fitler and tire pressure would be the most obvious things that I would check first... When you filled it up was the tanker truck at the station, making a delivery of gas? When they deliver gas, it kicks up all the ÅÅÅÅ and sediment at the bottom of the holding tank and it can end up in you gas tank. :xmas12:
the 5.29s are your first problem. you have 33s 4.10 will work fine on 33s. my DD tacoma has 32s and i cant even tell a difference and my rock crawler on 35s has 410s and i can notice a difference but i still get 17 MPG.
how would a plugged filter make me use more gas? that would make it starve for gas and cause things like hesitation and such, i don't think its the ff. tires are at 36psi
and 5.29's are high but I need them for offroad. anything less would kinda make my 3.slo struggle a bit much
all the obvious culprits: dist cap/rotor, plugs, plug wires, clean air filter and throttle body, fuel filter, o2 sensor, TPS, techron concentrate for fuel injector cleaning -- or seafoam, but i've never done it myself -- or FP60 which is a good inexpensive additive that you add to every tank of gas, tire pressure...
are you running your _original_ cat and muffler? maybe a clogged cat is contributing to the problem but not likely the sole factor...
I pulled the cap off and it looks decent, as does the rotor. The platinum plugs come out unfouled and pretty clean as well. The filter is a 3" cone and is clean, wires seem fine. Had it scanned yesterday, no codes at all. Cat is original, and has borla muffler, I don't think its clogged. It idles perfectly fine, and runs well. I am stumped as to why it got this huge drop in mileage. I'll see how the next tank goes, maybe it was just a bad fill of gas.
spiewaker
Dec 16, 2015 01:10 PM
That's whats in mine.
