Running Wires from Bed to cab...(Searched)
Old Dec 28, 2005 | 06:54 PM
Boaz's Avatar
Tomorrow I am hooking up some ProComp 130 Watt lights on my truck. I am mounting them on the roll bar.
The wires obviously have to go from the lights to the cab where I can hook them up to the battery. Is there a good location to run the wires from the bed of the truck to the cab/dashboard area?
Should I just run the wire under the truck? I am considering drilling a hole in the bed then running it under the cab floor board then drilling another hole and then running wires up to the dash...
Any Ideas??? Any Suggestions?
Jake
Old Dec 28, 2005 | 07:22 PM
LOCKnGO's Avatar
Under the carpet in the cab there are some plastic drain plugs (4) two on the drivers side and two on the passenger sde, you can runwire through them. In fact the harness for the fuel pump runs though the floor just follow that.
Old Dec 29, 2005 | 06:46 AM
Boaz's Avatar
thanks lock I will look for the fuel pump relay!
Old Dec 29, 2005 | 06:55 AM
mt_goat's Avatar
From the bed just follow the wires from your tail lights.
Old Dec 29, 2005 | 02:35 PM
LOCKnGO's Avatar
When I mounted my lights under the bed(for backing up light) I followed the passenger side framerail and ran the wires through the floor. careful tho i found some rust and that added to the project.
Jun 1, 2021 01:51 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
elwood73
Jul 5, 2015 07:07 AM
CJ94yota
Jul 3, 2015 10:14 PM
