code 13 and code 14(ignition signal and rpm)
Old Dec 23, 2005 | 03:17 PM
22REFORME's Avatar
the truck: 1989 toyota pickup 4x4 5spd 22re (170k)
the problem:
OK well i got this truck a week ago or so, and since then i have become increasingly frustrated. Initially, the truck was throwing a handfull of codes and hardly able to start let alone run but after sorting a few things out i had narrowed it down to code 13 and code 14(ignition signal and rpm signal). At this point the truck will start right up maybe idle ok for a couple minutes at longest and then stall out and throw the codes. when i got these codes i figured the coil was maybe bad or worst case scenerio the distributor.
So far i have replaced all the spark plugs, the cap and rotor, the plug wires, the coil, the control module/ignitor, the distributor and even the freakin ECU! i have spent a fair amount of time looking around for loose wires and have come up empty handed. does anyone have ANY ideas?
thanks so much in advance and happy holidays yota tech!
side note.. things i replaced b4 i got to this point include pcv valve, air filter, fuel filter, full brand new exhaust fromt the manifold back and i changed the oil twice.
Old Dec 23, 2005 | 03:34 PM
4runnermt's Avatar
Look around for dirty, or corroded ground straps. I had this problem on my chevy pickup. Replaced all kinds of stuff, and got similar codes. Finally I cleaned the ground strap from the frame to the ecu and its run perfectly ever since. Just an idea...
Old Dec 23, 2005 | 03:41 PM
22REFORME's Avatar
Yep i am already on track to do this.. just don't want to
Old Dec 24, 2005 | 03:30 AM
Boosted Chemist's Avatar
if u want dude, u can swap out your dizzy for mine and see if maybe its the dizzy. Or at least narrow down the problems
Old Dec 24, 2005 | 09:02 AM
22REFORME's Avatar
thanks man... but i already swapped out the dizzy... along with every other ignition component including the ecu!
Old Dec 30, 2005 | 03:25 PM
22REFORME's Avatar
ok gurus... i am stumped .. i am getting 13 14 and now 43 starter signal. i have re done the grounds and haven't found any loose wires. stumped!
Old Jan 1, 2006 | 01:43 PM
22REFORME's Avatar
Old Jan 23, 2006 | 05:30 PM
Blitzkrieg's Avatar
22reforme,
Any luck getting rid of codes 13 & 14? I have the same ones. They've been around for a couple years on my Toyota. The intermittent sputtering and coughing has gotten so bad now that it's almost undriveable. I've tried all you have short of replacing the distributor and ECU. Let me know if you have had any luck. Thanks
Old Jan 24, 2006 | 10:41 AM
motoracer47's Avatar
are u using the factory manual to troubleshoot this? all 3 codes relate to the leftmost connector on the ecu: 13 is NE signal, 14 is IGF signal, 43 is STA signal. , im wondering if there is a short somewhere in your wiring, or a problem with the connector or junction boxs.
Old Feb 24, 2020 | 06:47 PM
DBRobison's Avatar
Did you ever figure out what the problem was? I'm having the same problem.
Old Feb 28, 2020 | 07:23 PM
superex87's Avatar
Sounds like a failed/ failing igniter. The distributor sends its signal to the igniter which then converts the signal and sends that to the computer. Hence the codes for rpm and igniter signal. ECU then send the signal back to the igniter. Igniter then fires the coil. Find a good working OEM used igniter. Aftermarket are junk and plain dont work.
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
nonstop
Jul 24, 2015 06:29 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
