Ooops.....I think I just won the wrong camshaft!
Old Dec 25, 2005 | 04:48 PM
vmax84's Avatar
I'm such an idiot........will this camshaft fit my 89 4runner with a 4 cylinder engine?? Oh well............back to the drawing board!!
vmax84
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Old Dec 25, 2005 | 05:58 PM
vmax84's Avatar
Anybody know for certain if this camshaft will work? Thanks.
vmax84
Old Dec 25, 2005 | 06:11 PM
Elton's Avatar
if it dont you only lost $12
Old Dec 25, 2005 | 06:23 PM
vmax84's Avatar
Yeah, the 12 bucks isn't a big deal. I just "figured" that all of the 4 cylinder engines they put in the 4runner's and pickups were the same.
Guess I didn't know what the difference between the 22r and 22re were.
vmax84
Old Dec 25, 2005 | 06:36 PM
marko3xl3's Avatar
I am actually trying out a very old Electronic Toyota Parts Catalog someone posted here and even though it's weird to use, I think I can confirm that the camshaft you purchased will indeed fit your truck (22R as well as 22RE). The part number should be 13511-38011.
If you PM me your VIN, I could probably make sure, but this catalog is seriously awkward to use .
Let me know...
Old Dec 25, 2005 | 06:43 PM
suprathepeg's Avatar
Yea IIRC the 22R and RE are identical longblocks, its just whats outside that is different.
Old Dec 25, 2005 | 06:55 PM
marko3xl3's Avatar
That's all the models this camshaft fits IF I got the right part number, which I think I did.
Old Dec 25, 2005 | 07:07 PM
vmax84's Avatar
Thanks for the help.
vmax84
Old Dec 25, 2005 | 07:17 PM
marko3xl3's Avatar
vmax84
So you gonna keep the shaft once it arrives and try to install it?
Old Dec 25, 2005 | 07:25 PM
kyle_22r's Avatar
all cams are interchangeable between the 20R/22R/22R-E etc.
Old Dec 25, 2005 | 07:26 PM
vmax84's Avatar
Not sure yet. My plan for right now is to drain the coolant out of the engine (including the "block coolant" using the block drain) and swap out the cam in my engine without comprimising the head gasket.
Cam in my engine is junk.
vmax84
Old Dec 25, 2005 | 07:28 PM
vmax84's Avatar
Kinda of a long shot (swapping out the cam without wrecking the head gasket), but if it doesn't work, I'll simply press on with removing the head and have it redone at the local machine shop. Just have to try, though!!
vmax84
Old Dec 25, 2005 | 07:33 PM
marko3xl3's Avatar
Well, good luck. I hope all goes well for you!
Old Dec 25, 2005 | 08:24 PM
Just a question, but how do you know that the CAM is junk?
Old Dec 25, 2005 | 08:25 PM
marko3xl3's Avatar
I was wondering the same thing actually!
Old Dec 25, 2005 | 08:48 PM
kyle_22r's Avatar
lobes could've worn out or be badly scored.
Old Dec 25, 2005 | 08:54 PM
marko3xl3's Avatar
But how do you know if they are bad without disassembling the engine?
Old Dec 25, 2005 | 09:16 PM
DudeBud's Avatar
why buy a used cam with 140k on it. maybe if it came with the followers too it may be ok
Old Dec 26, 2005 | 06:55 AM
vmax84's Avatar
The engine runs good........starts easily, idles fine, good power........runs the way a toyota should, however, the engine is kinda "loud". I popped the valve cover off and the camshaft lobes on a couple of the lobes (or whatever you call them), there is some "shiney" parts missing.
So for now, I simply want to see if I can get away with temporarily fixxing the engine. If I can swap out the cam for now and get the engine to quiet down, then I'll be happy.
vmax84
Old Dec 26, 2005 | 07:06 AM
vmax84's Avatar
If the cam I receive is serviceable, what else am I going to need (providing I can pull this off without the head gasket leaking)? What do you call them......"followers"? Is there a "pad" that rides on the camshaft lobe?
I'll be getting back into the engine shortly and can't remember exactly what it looks like, but it seems like I should be able to purchase something new that rides on the camshaft lobe.
vmax84
