Paper or plastic?
Old Dec 10, 2005 | 07:11 PM
snap-on's Avatar
Paper or plastic?
SO im at the point in my 3.0 rebuild that its time to put the oil pump/ rear main seal/etc back on and i notice in my master seal kit it includes paper gaskets for
the various stuff that currently had RTV as sealant.
As this is defintaly NOT something i want to have to fix later because it starts leaking....
DO you go with the paper gaskets included in the kit?
OR
Do you go with RTV which was on it orginally?
Old Dec 10, 2005 | 08:01 PM
Glenn's Avatar
I've used RTV in other vital areas with no leaks whatsoever.
Old Dec 11, 2005 | 07:31 PM
snap-on's Avatar
Ive used RTV on the water pump and upper idler pully in the past, but im wondering what to do with the oil pump and rear main seal... (both of which i have paper gaskets for not to mention the water pump)
pros/cons of each...
Old Dec 11, 2005 | 08:08 PM
984RNR's Avatar
ive used rtv on both sides of the paper gasket and it has worked with out leaking
Dale Johnston
11
Oct 31, 2015 10:22 PM
whiteyota93
Sep 29, 2015 02:31 PM
mtrdrms
Sep 26, 2015 07:12 AM
Kylenicoll33
Sep 24, 2015 12:13 AM
imhousing
Sep 10, 2015 02:04 PM
