Manual 1994 4Runner
Old Dec 19, 2005 | 10:35 AM
Lanman's Avatar
Manual 1994 4Runner
Anyone know where I can get the manual for the 1994 4Runner 3vz engine?
It starting to hesitate on crank/startup. I sprayed some STP fuel injector cleaner. It helped, but it does not crank as quick as it once did. The problem does not happen all the time. On a cold day it may happen or not.
I need the manual to know the location of the parts that might need changing, like fuel filter, etc.
I also need to know what is the starting point of checking/resolving for this problem.
Thanks for any assistance ...
Old Dec 19, 2005 | 11:18 AM
jsnby's Avatar
if it's only happening when it's cold, i'd start looking at the electrical system. How new is your battery?
Old Dec 19, 2005 | 01:27 PM
Lanman's Avatar
Thanks for the reply.
The battery is about a year old. A battery test says 12.5v on the multimeter. Inside the dash says about 16. Lights are bright. The battery fluid test is within the range on the gauge, all cells.
Old Dec 19, 2005 | 01:33 PM
celica's Avatar
thin happened to my truck. It got to the point that it wouldn't do anything for the first second, then crank. It was my starter contacts. They were worn and dirty. It ends up that once the gap is bigger (from being worn) and they are dirty (carbon) they require mare amperage. When it is could out the available amperage in your battery is greatly reduced. I don't remember the formula but it is something like half the amperage is available at zero degree celcius. (35*)
I would check that out.
Old Dec 19, 2005 | 04:01 PM
the_4runnin'_beast's Avatar
you can get the manual at thepartsbin.com
Old Dec 20, 2005 | 04:04 PM
anthony1's Avatar
This is a FSM for 93 but it's shoud do the job.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Old Dec 20, 2005 | 04:19 PM
rocket's Avatar
1-800-622-2033
https://www.yotatech.com/showthread....ghlight=FSM%27s
Old Dec 20, 2005 | 07:02 PM
mach4's Avatar
Originally Posted by rocket
Linky no worky.
Could be just my pc.
Old Dec 21, 2005 | 07:08 PM
Lanman's Avatar
Thanks for the site. I now have something to refer to. I enjoy my 4runner and wish to maintain it as long as possible.
nanhodges2733
May 29, 2020 03:28 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Doug4320
Mar 24, 2018 10:11 PM
Road Bull
Oct 10, 2015 04:55 PM
ItsJustD
Jul 7, 2015 07:49 AM
