Parts transfer question
Old Dec 17, 2005 | 12:12 PM
bryanr's Avatar
Would it be possible (and fairly easy) to transfer the all of the cruise control and A/C components from a 92 4x4 to an 89 4x4? Would it be as simple as just pulling the parts and installing or is there anything involved with the ECU?
Thanks.
Old Dec 17, 2005 | 01:23 PM
Babypig's Avatar
The electrical connectors may be different, thats what i found upon rerofitting a 95 system into a 90. Try to get both ends of the connectors if you can then you can splkce where you need to. The rest should be okay though.
Old Dec 18, 2005 | 10:37 AM
Flamedx4's Avatar
JuvenilePorcine is spot on.
Old Dec 18, 2005 | 02:07 PM
bryanr's Avatar
Since I have the entire truck the system will be coming out of, hopefully it will be much easier. Thanks guys.
Old Jan 24, 2006 | 05:10 AM
bryanr's Avatar
Well, I got an answer to my questions to update this. The A/C swapped across no problems, but the Cruise is a different story. It appears my 89 doesn't have the same wiring harness as the 92 and therefore I can't plug the wires from the steering wheel into anything. Ah well. I'd rather the A/C anyway
Old Jan 24, 2006 | 05:40 AM
JamesD's Avatar
Cruise control solution...
I have your answer to your cruise control:
James
Old Jan 24, 2006 | 10:24 AM
Flamedx4's Avatar
Aftermarket cruise controls are under a hundred bucks.
Old Jan 24, 2006 | 11:32 AM
bryanr's Avatar
I'm not really worried about it. I figured since I had a parts truck it was worth the time, but I am not paying for aftermarket cruise, just not worth the $.
bigjstang
Jun 2, 2025 03:56 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
