- Replacing fuel injectors connectors ?
- Bad master brake cylinder? Well damn
- I NEED 3VZE HELP! in an 88 pickup
- New owner with window switch issue
- Places to get a 22r from
- Flutter noise around 2-3k rpm
- 90 3VZE Failing Emissions, High NO, High HC
- Windshield washer pump mystery?
- Starter or Solenoid?
- Hard Starting Hot 22RE Engine
- 95 T4R not passing emissions.
- R12A Refrigerant
- (89?) 4runner gauge cluster to 87 pickup
- 3vze code 52 troubleshooting
- 22RE misfire due to electrical issue
- interchangeable parts between 1st and 2nd Gen 4runners?
- 94 p/u suspension upgrade ?
- 1986 4runner Lurching/jumping when turning
- Is this head gasket safe to use?
- jumping te1 an e1 does NOTHING?! HELP
- What do yall think
- Cylinders 2 & 4 Not Firing
- 89 pickup firing order wrong
- Help! Fuel Light Glows w/ New Sending Unit
- 22re idle problem
- New radio probs.
- 91 Toyota speedometer problem
- SR5 Cluster
- No Crank, No Start very strange electrical issues
- Steering Column Lock? POLL
- Need wiring diagram for '90 pickup
- 95 4Runner no lockup
- Need help with brakes!!
- brake ?s 91 pickup 22re
- 93 22RE -- Idle hickup and gurgle sound
- Where did the lift tire/wheel spec thread go?
- 22RE overheats with AC on
- Timing belt
- Timing Chain wedge?
- Stock clutch replacement
- 94 pickup (22re) slow warm up after rebuild
- 3.0 hesitation tps?
- 1990 Stabilizer bar bushings
- 94 4runner starts for 1 second then dies. PLEASE HELP
- Cold start injector gasket?
- 88 3.0 Timing question
- 1986 fuel pump problem
- 1st Gen 4Runner owners-what does your title/registration say?
- Rusty fuel sending unit removal
- 94 3.0l Cold Idle????
- Starting Problem
- Intake Backfire Help 22re
- 93 PU Empty clutch master cylinder.
- Having trouble IDing part
- Tranny/Transfer case questions
- 22RTE block taking 6 qts
- First Time Head Gasket and Timing Chain Questions
- Dragging Clutch
- 1991 DLX Extra Cab Bumper Question
- exhaust valve diagnosis whats your opinion
- Need to find a mount
- 91 Toyota 22re engine noise help!?!
- Rear Shock Mounts - 89 Pickup
- 92 T4R replacement keyless entry
- information needed on one of a kind decals
- running external fuel pumps
- Brake fluid leak. Is this a LPSV?....
- bleeding master cylinder problems
- cold start injector problem
- Custom light bar?? For a 1st Gen 4runner
- 93 4runner ISR mod low(er) idle
- 94 pickup 4x4 clutch issues
- Broke EGR vacuum modulator...
- No top end oil pressure ? See pic please
- quick 1st gen 4runner speaker question
- 4-5 IFS lift + ball joint spacers. Need shocks
- Exhaust Donut Gaskets
- any way to identify this wire?
- Timing issues
- 91 3.0 pickup ignition problems
- air bag light
- Some suspension questions
- Engine stumble 1989 pickup 22re
- 3.0 timing issue
- Best bang for the buck 95 4Runner replacement
- 3.0 won't start or run with TPS plugged in
- 1993 SR5 -->4x4 Actuator Assembly<--
- Truck keeps blowing fuel pump fuse
- 3VZ-E Rebuild Tips
- Very strange noise from Pass Side Floor Board
- New to the forum, need some advice on a lift kit for a 93 2WD Pickup.
- 94 4runner Rear window strangeness
- Timing and Smog Check Question
- No high idle with AC on?
- Motor Swap
- Exterior Rearview Mirror Removal
- RPM/Throttle Issue
- Head gasket question...
- Oversize valves for 3vze still available?
- Code 21,25&26
- Brake issue Help
- My 94 Pick Up problems story
- A340H Park/Neutral Switch Inter-Year Compatibilty
- Backyard Paint Job on my Runner with GCI Military Paint
- 93 sr5 potential lift!
- Coolant Sendor Help Needed
- Please HELP! No cel. battery light on...no crank 1 loud click...
- Inside door handle Plate
- Replacing front sway bar end links - 92 pickup
- 87 22re fresh rebuild
- hole in my battery
- 92 22re dies after 2-3 seconds
- fuel line order
- Failed Smog...High NOX
- 1991 Toyota truck spring flip ubolts help.
- Best Brand ATF for an Older, High Mileage Transmission
- Best place to buy VAFM
- 87 22R-E Sputter and Idle issue...help!
- replaced head decreased MPG
- 1st Gen Dash Pad- 2 styles?
- 2nd and 3rd gen pickups 2wd - trim packages?
- Automatic locking hubs?????
- Sas amazing deal
- 1995 4Runner cooling issue
- good shop in North Chicago?
- poor mileage and mystery part?
- Interchangable parts
- Fuel spewing out of tailpipe.
- 1st and 2nd gen 4runner push bar compatibility
- 93 22re wont start
- Steering box power piston nut?
- Keyless Entry Fob Program - 92 T4R
- Wiring Hunt!!
- Fluid in lower airbox
- 88 4runner 3VZE 5 speed
- Is this a sign of bad TPS? 22re
- Chevy 63" spring lift
- Squealing Clutch!! Need help!
- steering column play
- 3.0 REALLY bad gas milage.
- 94 4Runner drivetrain swap?
- radiator fluid in oil
- front suspension problem HELP
- stock fender swap?
- 2wd spare tire winch with a 4wd tire
- 93 SR5 issues
- 91 22re, no compression #1 cyl according to mechanic
- Running/Taillight issues
- Rear end whine?
- 1988 pickup e-brake stuck in or open...
- How to Properly Adjust 1st Gen IFS Torsion Bars to Factory Specs (Via the SM)
- Transmission issue
- Blinker issue odd citation
- Got a 95 truck with 3.0 wanting to 3.4 swap
- Ifs upper control arm
- Driveshaft question
- 89 3.0 running troubles
- is it possible to run a 3.4 on the 3.0 ECU?
- RPM Signal from Engine Swap ECU to Stock
- CV Boot Replacement - 92 Pickup
- Brakes binding while backing up after running through puddles...
- sticking brakes
- '94 4x4 PU - overheating :(
- 22re having a misfire under load, and sometimes at idle. Down on power.
- Early TB air boot on late 22RE?
- Cv axle hardware question
- Replace foam in vents
- Dead Runner
- 3ave Speed Control Module?
- My new project
- 1986 4runner power steering gearbox
- 92 4 Runner Stalling
- 3 Replacement TPS', 3 different vendors--all bad?
- 87 22r spark plug recommendations
- 3VZE Major Tune Up
- 1990 toyo issues
- 94 pickup 5 lug suspension
- A/C Idle Clarification
- 22re Rattle on Acceleration
- 91 22re cranking issue
- what happened
- Need help finding a high side R134 fitting that fits properly
- gutless 22r
- IAC Secondary Gasket Question
- 93 yota 4x4 22re brake light
- 1988 4Runner
- Replaced rear diff pinion seal, now I have a low rumble on deceleration
- Torsion bar problem
- Spark Plug #3 keeps fouling- '87 22R
- I just can't find where I am leaking coolant out of.
- Transmission questions
- HELP! 89 P/U drive train noise (I think)
- removing 80-A fuse
- buick 231 swap parts
- wiring harness and injectors
- Question about fuel tank install
- Missing diagnostics port/random loss of power on petrol
- Drive shaft bolts questions
- Tach Signal on an oscilloscope.
- Encountered problems replacing head gasket. How to proceed?
- 89 P/U starts but wont run.
- W56B Trans Reassembly Problem
- 91 4Runner Starting Issues
- 87runner Shock up grade and bj spacer install
- Help my EGR woes... 1993 3VZ-E 4x4 dlx 5-speed
- Rustoleum hammertone paint
- Bearing type noise in tranny bell housing
- 86runner acting crazy
- 1994 toyota pick up
- Stuck in Gear
- Best cam to run for 22r??
- Timing issue
- How to access the blower motor dash switch?
- 3.0 to 3.4 Success Stories
- 3rd Gen Pickup Electrical Issue? Help!
- 1st gen 4runner wont start when warm
- 1995 2wd trans problems
- Fuel Pump - electric vs mechanical?
- Strange starting issues
- Rough idle after motor swap!
- Transfer case!!
- Timing Set
- Loss of power
- URGENT HELP REQUEST - 3VZE Distributor install
- AC Cut relay
- O2 Sensor Questions
- 86 Toyota truck Headlight adjustmunt?
- Bottom of passenger seat picture
- bolt snapped in blind hole in header
- throttle body question
- Throttle body replacment?
- 91 22re pickup won't stay running
- Odd Problem With Starting
- Yes ..another 22re starting thread
- 22re electrical problems
- 22r extra cab diesel 3l swap
- ignition switch 94 4x4 PU
- Toyota techs please reply: Intermittent Starting issues with 3.0
- Start fresh?
- 95 4runner 4WD with nasty chatter from TC
- Help with TPS test
- 22r Smog troubles
- Torsion Bar trouble
- Questions on Rebuilding my 94 Toyota Pickup 22RE.
- How to identify the right OEM parts?
- 1992 4Runner Decelerates Uphill at Interstate Speeds
- 88 X-cab V6 Frame replacement parts or Frame? What years fit?
- led light bar brackets
- 92 4runner 3.0 milky oil
