94 pickup 4x4 clutch issues
Old Sep 1, 2015 | 05:15 AM
94yota212's Avatar
Just got a 94 pickup 3.0 4x4 last week an you have to push clutch pedal all the way to the floor to shift I tried changing master an slave cylinder an that did not help just trying to find out if this is a common issue or if it's not a problem at all? because my 86 an 96 where not like that
Old Sep 1, 2015 | 05:43 AM
AKHeathen's Avatar
did you get all the air out via gravity bleed? when you have your foot off, it should open up all the way to the bleed screw. if there is any air at all trapped in there, it will not push all the way. once that is ruled out, spray wd-40 on the throwout bearing and input shaft.
Old Sep 1, 2015 | 05:50 AM
94yota212's Avatar
Yeah got all the air out an adjusted master cylinder rod as far as I could the clutch pedal doesn't feel soft it just will not let you shift into gear without pushing all the way to floor
Old Sep 1, 2015 | 05:54 AM
AKHeathen's Avatar
wd-40.
Old Sep 1, 2015 | 05:56 AM
AKHeathen's Avatar
oh, did you get a good flow while gravity bleeding? i;m unsure if you can adjust that rod to the point it won't let the mc park to the open port for bleeding. might be worth backing off till loose then bleeding again.
Old Sep 1, 2015 | 05:59 AM
94yota212's Avatar
wd-40.
I will try that when I get home
Old Sep 1, 2015 | 06:45 AM
94yota212's Avatar
I adjusted rod after bleeding line
Old Sep 1, 2015 | 07:00 AM
RJR's Avatar
RJR
Do a search for "clutch bracket fatigue" or "clutch bracket cracking" or something similar. A somewhat common problem is for the pedal bracket to crack, and then it twists instead of forcing the push rod to activate the master cylinder.
Old Sep 1, 2015 | 07:47 AM
94yota212's Avatar
Checked that already brackets in good shape no cracks
Old Sep 1, 2015 | 08:01 AM
RJR's Avatar
RJR
If the bracket's in good shape and the system is properly bled, then next check the pedal and push rod adjustment. Instructions are here:
http://personal.utulsa.edu/~nathan-b.../2checkand.pdf
rondogracing
25
Dec 11, 2015 07:26 AM
1stTimer
Jul 4, 2015 11:56 AM
marcusSRG
Jun 27, 2015 07:13 AM
bprice0077
Jun 25, 2015 07:36 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
