- 1996 bed on 1990 truck?
- 1994 4X4 Pickup 22re Cold ignition problem
- I believe I might have a blown gasket?
- killing the truck. POWER!! 22re plow truck
- 91 toyota 4x4 weird noise please help
- Need help identifying part!
- 91 22re code 14
- New full rear leaf packs for 132$ a pair... shipped!
- what code?..
- who makes rear bumpers for 2nd gen 4runners?
- Converted to H4 Headlight, Wow, I can see...
- 92 toyota 4runner 4.88 gears ??????
- Custom panhard bar brackets?
- Brake upgrade
- Official snow pic Christmas thread?
- down-broke in roanoke
- Radiator 4x4 vs. 4x2 will it fit
- Noob looking for help
- Odd, intermittent, squeaking coming from front wheels?
- 89 toyota pickup extra cab
- 1991 4Runner head gasket repair
- Bad wiper switch?
- High beam not working when pushed, but works when pulled. 1/2 works
- 35x15.5 Super Swamper TSL SX on 15x8 wheels - Pics Inside!
- Transmission will not line up on the bottom 95 4runner
- o2 Diagnostic problems (code 25)
- 1" bodylift
- 87 4Runner Brake and Charge light on, alternator bad
- Help!! Electric fan problem! Melting fuse boxes!
- 95 4runner seat swap with a 92 Toyota pickup
- A plea for diagnostic help! 3VZE
- Trail gear bull bumper mod?
- 1994 4x4 Pickup Control Arm availability
- head gasket thickness ?
- Need to re-gear with 31's ??
- 22re coolant hoses under intakeM. - any ideas?
- Clutch replacement question
- 22RE "ticking"
- 1991 4runner seat swap with 1997 4runner
- Need help with gears
- Wheel bearing? floorboard
- battery and brake light on
- 1994 V6 4Runner low idle/stalling issues
- Lifted 4x4 88 pickup transfer case issue.
- Winch installation question - bullbar not suitable?
- 37's with 22RE, 5spd and stock 4.10 gearing?
- Digital Dash
- Which efan
- to rebuild my 22r
- 1st gen: Snorkel Install - Easy?
- clunking sound
- Is this an igniter problem?
- New Beginings - To build or not to build.
- BUY with a CODE 52???
- Wire harness swap question
- Build up on #1 spark plug
- far from home, overheating 3vze
- 86 sliding glass rear window on a 92?
- 1990 4Runner window problem fix
- Doug thorley header problem!!
- Has anyone heard from James Dean lately?
- Wabfab Perfect parts
- 86 -89 toyota pickup fsm help
- Autozone universal coolant
- clutch slipping
- bad vibration after SAS
- Gearing
- newbie Toyota owner 22re
- Exhaust Leak
- death wobble
- 86 22r wont start unless you pour fuel in the carb but theres fuel to/in carb!?!?!
- New owner - 87 4runner! A beast!
- Reman recommendations
- Tach reading low.
- 3vze diagnostic Code 24...shudder/miss/rough runner
- jaguar alternator swap 120
- Loud Whining Noise when turning the steering wheel and when pressing the brake pedal
- 3.0 3vze wont start after new belt
- Need help on 2,000 rpm idle and loping
- Found oil around knock senor when doing headgasket????
- head light not adjusting.
- Fixing Ign. bypass, need some wiring help..
- 1991 Sr5 intermittent engine issues.
- Where is the AC low pressure switch located 1987 pickup
- pulling 3.0 for 3.4 swap
- Truck Won't Go
- Catalayc converter
- Auto transmission issues
- Engine surge from hell...what could it be?
- manual hubs question
- Bypassing rear window relay, but still want it running of the ignition
- shortening wheel base
- Disconnected hose, is this ok?
- celica head in a 4runner?
- Blower motor problem after GM Alt swap
- engine cuts out at 4000+ rpms (22re)
- Starter problems!
- 1993 pickup won't start
- speedometer cable
- Windshield Washer Issue
- red LED guage pics???
- My a340h shifts at 4000 any way to make it hold gears longer?
- Loose shifter guild pins
- 3vze Head Gaskets what else do I need?
- tps adjustment
- how hard would this be?
- Ground issue
- Starter doesn't engage flywheel
- Is my oxygen sensor busted?
- 3.0 knock sensor..HELPPP
- Does my 93 runner have a stock front diff lock?
- blower problems
- New 22RE IAC Valve?
- Power Steering fails - Check your Reservoir!
- Mechanic's in Cleveland
- 22r choke pull off
- A/T oil temp light stays on always even when first started
- 32/36 Weber Man. choke or 38 Weber Man.choke for a 22R?
- Speedo swap
- head gasket or clogged radiator?
- Distributor, timing
- need help on rebuilding 22re
- Who wants to finally see homemade hoodscoop?
- Where to find white fender
- Extreme engine noise
- 90 22re idle
- Rocker panel protection
- Looking at first 4runner
- Hot idle/ restart rough idle and stall
- 90-95 4runner
- Electrical Starting Problem...I think
- 3VZE Ignition Timing Questions
- 3.0 head issues ongoing?
- suspreme suspension
- marlin rear bumper and motorcycle
- Check Engine Light?
- my truck lives!
- aFe Pro Dry S air filter doesn't fit
- My truck won't start. Please help!!!
- 3.0 V6 Timing Question
- 3vze hot start, ect?
- SR5 Gauges Work in 22R (carbureted)?
- Fiberglass Bedsides
- Old Man Emu Suspension Kit Installed....
- Heater Problem 22re no heat
- whats a longer drive line for a 86 long bed extra cab
- 87 22R - Still Have Rough Idle After New Carb
- PIC REQUEST: trimmed and cut 4Runner's
- My 87 Pick up build
- Heater Temperature problem
- new guy needs help!
- 1990 3VZE Upper/lower rad hose temp difference??
- Valve adjustment - DIY or shop?
- no power to ignition
- blower motor stopped working???
- need advice gettin my r12 system runnin again
- Wiring GM 1 Wire Alternator for 93 Toyota 4Runner 22RE
- Coolant & Bell housing
- Flip pac camper
- New member wanting to know where to start
- driving with blown head gasket
- Quick question about milage calculation and re-gearing..
- rear end vibration !!!!!!
- brake lock up
- 3VZE - Fuel Cut Solenoid
- fuel door hinge help !!! I need your wisdom or ideas
- Pitman Arm Problems
- Fuel Sending Units
- 1995 4Runner with old ecu
- Instrument Cluster Wiring
- Another rear sag thread
- Weird cluster light issues on a 1990 4R
- 22re timing adjustment
- 1st time rebuild, getting started help? Las Vegas
- Front End Alignment:Where to Start?
- new member sayin "hi"
- 22R Carb Swap - Gasket Question
- Rear bumper removal. 1st gen 4runner
- '89 4runner rear seat back pins/bolts?
- radio ground wiring
- grey smoke, smells like fuel, burns SO rich
- What do I need to put ac in my yota
- New HG installed. Yotatech Rocks!
- Aisin hub bolt issue
- 91 22re, will crank but wont start. WHATS WRONG?!?!1one
- losing coolant and surging idle 22re
- Trail gear coupon?
- CTS help
- 1989 4Runner (22re) stalls and will not start after warmed up
- wire tach to an SR 5 cluster. 85' runner??
- Anybody know what this is?
- 1986 extended cab 4x4 axel options
- 93 3vze couple questions
- Thermostat bypass hose
- 93 Toyota Pickup 2WD Tranny & Rear End Oil Capacity ?
- TOYOTA decal not sticking to tailgate... cold weather
- Fresh 92' 22re Wont Start. WEIRD.
- Shifter Moving All Around
- Front third swap. Now its binding up in 4x4!
- Help me with my clutch.
- '86 SR5 brake lines
- Warm Start Issue Still getting me...
- heater not working as well as it should-water pump?
- 1988 toyota 22re
- New 'Yota w/pics...and "?'s"
- that damned clutch pedal bracket got me
- Changing headlights on 1987 4x4 - do I really need to remove the grille?
- code p0440
- 1st Gen 4Runner: Aftermarket shackle width question
- Auto to manual transmission
- Removing unneeded smog equipment?
- Anyone have any pictures of new Head Gaskets Installed? 3.0 V6
- Well I'm an Idiot (Knocking/clacking noise)
- Stock LC shocks vs ES3000
- crappy idle when cold outside?
- SPARKS89 Build-Up
- Push bar swap???
- can a fuel pump run slow?
- Trail gear bumper painted?
- New powers testing pump & idle up valve
- 1992 22re Pickup - Major Oil Leak
- 94 pickup has violent vibrations in reverse
- 36-38s w/ IFS. who has it? pics?
- Christmas time! $100 spending limit.
- Help with choosing what trans will work
- is TOTAL CHAOS the only maker of lower a-arm uniball conversion?
- 22re first crank no start second crank fires rite off
- Another head gasket thread
- 3VZE code 25
- sbc with TBI into 88 yota
- Exhaust system
- 94 yota deluxe 3.0 5 spd Starter problem
- bad knocking in 2H
- 22RE burps / deep rumbling noise at higher RPM
- 2PC Dash to 1PC Dash swap Complete!! MUST READ!
- 22re ring seating/head gasket question
- another 3.0 to 3.4 swap inquiry
- 02 gears in a 87?
- What is the best width to go with on a custom front housing?
- tooth pattern help
- What is a T series Toyota?
- Converting auto to 5 speed manual
- Drilled out oil pressure sender - Need help
- 1990 Toyota pickup, 7ft bed to 6ft bed.
- Shock preferences
- 3.0L Backfiring and general loss of H/P and Gas mileage
- 87 22R installed new head now cant et timing at right.
- frustrated
- 86 22r Carb not taking fuel
- Quick question regarding valve adjustment
