power steering air valve
Old Dec 29, 2005 | 04:59 AM
jreynold's Avatar
Question power steering air valve
1990 4runner v6 4x4 190kmiles
Just got done replacing the water pump, fan bracket, radiator and belts.
when going to remounnt the power steering pump, I broke off one of the two ports on the air valve to the power steering pump. If I just plugged up the vaccuum line and left it alone what would happen? Where do I get this part? Only parts yard with a 4runner is a million miles away.
Old Dec 29, 2005 | 07:22 AM
Sequoia'd's Avatar
Angry
Better start driving... a million miles is gonna take awhile
Actually, you will probably have all kinds of problems if you don't fix it. If you have a pic would help in seeing if it's fixable (before you drive a million)
Old Dec 29, 2005 | 02:17 PM
Sleepydog's Avatar
It is an idle up valve that kicks in for the PS pump at full lock turns. They cost about $100 at the stealership - good luck finding one not already broken at a boneyard. Both of the ports on mine were broken off when I bough my truck - vacuume lines are plugged - Have had no problems at all (after about 15k miles).
Old Dec 29, 2005 | 02:25 PM
jmach1's Avatar
When I broke mine most of the junk yards wanted me to buy the entire pump. I finally found a yard that let me go find the part and remove it. Cost me 5 bucks. Good luck.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
cars-guy
Jul 11, 2015 07:51 PM
jon.r
Jul 11, 2015 03:34 PM
skoti89
Jul 8, 2015 12:05 AM
