Where to mount?
Old Mar 10, 2009 | 04:40 PM
Slashdawg's Avatar
Where to mount?
Where is the best place to mount a A/T cooler for a 92Runner?
Old Mar 10, 2009 | 04:41 PM
Tubbyfatty's Avatar
Right behind the rad?
Old Mar 10, 2009 | 04:42 PM
Slashdawg's Avatar
OK Thanks!
Old Mar 10, 2009 | 05:55 PM
mt_goat's Avatar
I think he means in front of the radiator. That's where most peeps put them.
Old Mar 10, 2009 | 09:59 PM
abecedarian's Avatar
Considering the stock cooling for the ATF went through the radiator, just about anywhere in front of, or behind the radiator will work, but if you want the ATF as cool as possible, either before the radiator or below it (behind the skid plate maybe?) would work.
Atf doesn't work well if it's too cold and burns up quickly if it's too warm, which is why it's routed through the radiator "stock" so the coolant can warm it up quickly and can absorb extra heat when the ATF gets too hot.
Old Mar 11, 2009 | 04:24 AM
mt_goat's Avatar
I don't see how you would put one behind the radiator, since the fan and fan shroud is there. Now I have put one or 2 between the radiator and the AC condenser before.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
voiddweller
Oct 2, 2015 07:47 AM
Brodetski
Sep 30, 2015 11:50 PM
