gauge cluster swap
Old Sep 25, 2012 | 02:37 PM
toyopower's Avatar
gauge cluster swap
I have a 1994 22re 4cylinder Toyota pickup with just the basic instrument pannel speedo temp and gas what i know is if I can take a 4cylinder gauge cluster out of a 4cylinder 4runner with a rpm gauge and see if it can work does anyone if it will work.
Old Sep 25, 2012 | 03:04 PM
cred92's Avatar
What you need to find out is if your truck is electronic speedometer or cable and find out what the 4runner is and if their both the same than yea you can swap um and won't have to adjust the tach. If your truck was prewired for the tach if not you may have to run a wire. If you do the swap unplug the idiot light sensor so you don't ruin the oil gauge until you swap in the oil pressure gauge sender.
Old Sep 25, 2012 | 03:12 PM
hgill's Avatar
a 94 truck will be most likely be a electronic speedo and will have tach wiring already pre-installed.
As for the swap, electronic speedo was in trucks from 92-95. It can be either from V6 or 4cyl, if it is from v6, then you have to turn a white pot at the back to adjust the tach readout to match 4cyl.
Old Sep 25, 2012 | 03:27 PM
Discombobulated's Avatar
Here let me search that for you.........................
https://www.yotatech.com/forums/f116...w-pics-179106/
Old Dec 25, 2012 | 03:45 PM
maroon94's Avatar
I have the same setup and would like to go to a gauge with tach, I've got a 94 22re 5 speed 2wd, its got the electric speedo.
And I was hoping my original cluster was BAD because the speedo and odo dont work, that way when I put in the sr5 cluster, it would hopefully fix the issue, but nope... side note: My buddy has a 95 with elec speedo that is willing to swap the sensor to see if it fixes my issue, so I'll know that result on the weekend.
I already looked at the search that Discombobulated posted about, and read it in and out, didn't solve my problem, and another side note: the truck in that sr5 cluster swap with pics thread is a cable driven system anyways. I dont know what toyopower has (cable or elec, I'm assuming cable since he didnt post anything later).
I actaully went to a junkyard and got 3 clusters with gauges cheap cuz my mom works in the office, the gauges were from two 93 4runners and a 95 4runner (all 3 were with v6's but it shouldnt be a problem cuz I could just adjust the tach, but they were all automatics, so I dont know if that effects the outcome) and I couldnt find any pickups with gauges, or speed sensors to steal from.
Anyways, I tried all 3 of the gauges and none of them worked, so I'm wondering if all three were bad( I doubt), or if my truck is even wired for it, or if it is then I could have an electric signal problem to the tach. I looked through the 93 fsm manual I found on another thread, the website is:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/index.html
On that site it doesnt tell you what color the wires are supposed to be for the connectors in the back of the cluster, and I cant find one for 93 or 95 4runners to compare to.
I'm driving back up to NorCal tomorrow morning cuz I was down in SoCal visitng, I'm gonna return them and get my money back from the junkyard
Any help would be appreciated, I've done a bunch of searches and havent come across anything to solve it
Old Dec 27, 2012 | 04:44 AM
maroon94's Avatar
And when I say solve it I mean like checking voltage at this pin or that one you know. Resistance checks aren't always reliable
Old Dec 28, 2012 | 04:55 PM
plocc31726's Avatar
My question is almost the same, but i bought a cluster w tach and oil etc. for a 89-95 will it fit on a 87 4runner? will it be pnp? any help would be appreciated
Old Dec 30, 2012 | 03:27 PM
Co_94_PU's Avatar
Will it fit, Maybe.
Will it be a pnp, Probably not.
go here. https://www.yotatech.com/forums/f128...-years-156128/
You will need both,
"1987 Toyota 4-Runner Factory Service Manual"
"1990 Toyota 4-Runner Factory Service Manual"
Old Dec 30, 2012 | 03:48 PM
plocc31726's Avatar
I was afraid of that, but i only paid 50 bucks for it so maybe i'll try to get my money back by reselling it thanx
Old Dec 30, 2012 | 04:18 PM
NautiRedneck's Avatar
I have a 93 that came original with standard gauges... did the swap and it was simple worked like a champ... just get you a sr5 cluster and it is plug and play
Old Jan 1, 2013 | 10:25 AM
maroon94's Avatar
Not on every truck. I'm a 94 and it didn't work pnp. My buddies 95 didn't work pnp either
Old Jan 1, 2013 | 11:22 AM
plocc31726's Avatar
The bottom line is, from reading all the posts you can get it to work with a little hard work
Old Jan 1, 2013 | 01:00 PM
plocc31726's Avatar
Well just came in from taking out the old cluster to see if it would fit, and No go it didn't even fit in the hole and i have three plugs and the other one had four so there goes the answer.
An 89-95 4runner cluster will not fit a 1987 4runner. thanks 4 the replies
80Truck
Oct 12, 2025 07:25 PM
gary4runner
Sep 24, 2015 12:53 AM
Esibnitsud
Jul 30, 2015 08:21 PM
Logz808
Jul 26, 2015 07:09 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
