22RET tuning
Old Oct 27, 2008 | 07:14 PM
STEvil's Avatar
22RET tuning
Anyone have a few tips on making a bit more power with a fuel injected 22RET?
I was thinking of running it at about 10PSI instead of the 6 it makes now but i'm not sure how to check for detonation, pinging, or if i'm leaning it out too far...
Wouldnt mind running a bit higher than 10 btw, just thought 10 was a good first point to start considering its all stock
Oh, and anything I can do for my transmission? It doesnt seem to change gears quite right sometimes (shifts from 2 to 4 then back to 3 at times, goes directly to 3 sometimes when changed from park, and off the line seems to slip sometimes).
Might just need a filter change maybe..
Old Oct 28, 2008 | 08:52 AM
annoyingrob's Avatar
Change your transmission fluid, and add an intercooler
Old Oct 28, 2008 | 09:09 AM
saitotiktmdog's Avatar
Indeed. Stand alone or something similar. Ask dcg981 about megasquirt also.
If not that upgrade your afm and injectors. That with the intercooler would be a good start. Eventually I would convert to a garret turbo and ditch the ct20. maybe even upgrade the manifold.
Old Oct 28, 2008 | 02:44 PM
FYI: Here's my upgrade solution for my 22R-TE:
-Megasquirt (I finished the harness, just need to install it)
-CT26 turbo (sitting in my garage)
-Intercooler (JZA70 intercooler in my garage)
-7M-GTE 440cc injectors
-Metal head gasket, and ARP head studs.
-3" exhaust.
Old Oct 28, 2008 | 04:54 PM
sh0kk86's Avatar
http://www.toysport.com/Technical Information/22r_tech_notes.htm
heard of guys having problems with runnign to much more than stock boost on a stock 22ret
Old Oct 29, 2008 | 09:16 PM
STEvil's Avatar
Link didnt work, site is under construction.
I tossed the owner an email though.
Old Oct 29, 2008 | 09:25 PM
94toyotapickup's Avatar
hey ill sell u a used ct 26 turbo, it dont look like its in bad shape previous owner siad it just needs a new bearing, i havent looked into fixing it cus i got anotehr ct26 that was new, just been laying around, and for the intercooler just put a stock supra intercooler on there, i think there good for up to 14ish psi.
Old Oct 29, 2008 | 09:27 PM
sh0kk86's Avatar
http://www.toysport.com/Technical%20...tech_notes.htm
its working
Old Nov 9, 2008 | 03:52 PM
STEvil's Avatar
Ah nuts, now my truck is having issues starting (crank crank crank frank sputter sputter sputter die... repeat several times)... I think I need to change the fuel filter or pump... or something.
What is the adjusting knob on the front of the EFI for?
Old Nov 9, 2008 | 04:23 PM
space-junk's Avatar
found your problem! you got a frank under your hood!! ditch the frank, and everything should be fine...
Old Nov 9, 2008 | 05:35 PM
abecedarian's Avatar
what adjusting knob?
Old Nov 9, 2008 | 07:58 PM
STEvil's Avatar
Very front, has a slot for a flat screwdriver. Turn it all the way down and idle slows down or turn it up and it speeds up.
Could be floats maybe I guess...
Old Nov 9, 2008 | 08:45 PM
Fofo's Avatar
www.22rte-trucks.com
Lots of info there
Old Nov 9, 2008 | 08:51 PM
oh, the idle speed adjustment screw?
that's all it does- allows more or less air around the throttle in order to control the idle speed.
idle air/fuel mix is controlled by the ECU in accordance with the coolant temp sensor and airflow meter.
Old Nov 9, 2008 | 09:31 PM
STEvil's Avatar
If thats what it is, it has very limited adjustment to increase idle. Oh well.
Old Nov 10, 2008 | 08:03 PM
STEvil's Avatar
fiddled with the adjustment screw a bit, starts beautifully now.
I guess it has a sweet spot...
Old Nov 11, 2008 | 06:18 AM
Emt-Iyotaguy's Avatar
you can go about 10 psi i think but you run the risk of hitting fuel cut if you get into it to hard and beleive me if you hit it you'll know every time my truck hits it my head goes to the steering wheel and then to the back glass over and over until i let off
Old Nov 11, 2008 | 04:04 PM
STEvil's Avatar
Found a good read, all about the 22R-ET, CT20, and T3/T4 Hybrid
http://www.well.com/~mosk/biggerturbo.htm
13psi on stock injectors: http://www.well.com/~mosk/boost.htm
Holy hell I love this site!!
Adjusting the 22RTE AFM: http://www.well.com/user/mosk/AFM1.htm
Direct link to the site: http://www.well.com/~mosk/welcome.htm
Poor fuel mileage? Read this: http://www.well.com/user/mosk/Vfsignal.htm
ladybugRC
458
Aug 21, 2020 10:41 AM
MadMax48
Mar 3, 2020 10:33 AM
urabus
Nov 10, 2015 07:38 PM
the_supernerd
Oct 1, 2015 09:20 PM
