Headers installed, need help with blocking heat
Old Apr 24, 2012 | 05:39 AM
jvsr5v6's Avatar
Headers makes great improvement in power but floor is very warm. What can I do to block off? Thanks in advance.
Old Apr 24, 2012 | 01:44 PM
ogjohnboy's Avatar
get some header wrap from your local parts strore and wrap it all the way from the header flange to the collector.
Old Apr 24, 2012 | 01:55 PM
92 TOY's Avatar
depending on the warranty, you may void it if you wrap the headers. I bought some heat shield stuff from the parts store....sticky on one side, comes as a sheet about 24'' x 16'' ,cuts with scissors, and I was able to provide protection for the floor, brake lines, starter and wire harness (headers are on a 3.0).
Old Apr 24, 2012 | 02:05 PM
Motox711's Avatar
http://www.summitracing.com/parts/THE-11002/
This is what i am doing. hopefully it works.
Old Apr 24, 2012 | 02:56 PM
ogjohnboy's Avatar
Curious, how could wrapping headers void warranty? Your arent altering them in anyway, wrap is removable and doesnt damage the header. In fact, wrapping the header is only an improvement because its promotes proper heat flow through the header and will help prevent them from warping or rusting.
Old Apr 24, 2012 | 03:00 PM
Outsane's Avatar
there are lots of arguments about the header wrap holding on to moisture and promoting rust
Old Apr 24, 2012 | 03:44 PM
92 TOY's Avatar
I'd have to have you direct that question to Doug Thorley headers.
see Item #2 in the warranty http://www.google.com/url?sa=t&rct=j...BN2gi0078e7Atg
Old Apr 24, 2012 | 10:15 PM
ogjohnboy's Avatar
hmm well seems that doug thorley must use some very low grade metal if its "degrades and deteriorates" the header. Wrapping it wont trap moistures, it actually protects the header. Thats would be the same as if they said painting the header with high temp exhaust paint will void the warranty. Wrapping the header would only be beneficial. If it was so bad, they wouldnt sell it.
But what do i know, im just a metal worker, not a header manufacturer.
Another option of what you can do, is just what 92toy said, they have material that you can stick to your floor board thats alot like dynamat that will soak up and then dissipate heat.
Old Apr 25, 2012 | 06:05 PM
jvsr5v6's Avatar
Thanks all for the suggestions.
Old Apr 25, 2012 | 06:27 PM
BMcEL's Avatar
If it was so good, it wouldn't void warranties.
Old Apr 25, 2012 | 08:35 PM
Greg_Canada's Avatar
Lots of places that make downpipes for turbo cars will not warranty it whenyou wrap them, they trap in heat and crack. Ceramic coating is best, then insulation on your floor...
Old Apr 26, 2012 | 12:07 AM
TNRabbit's Avatar
Everyone who has done headers finds it cooks everything under the hood. Part of the issue is there is about 10 times the surface area, plus the metal is extremely thin compared to stock exhaust manifold.
I don't know that anyone has completely solved this issue...
Old Apr 26, 2012 | 06:58 PM
I got my headers sprayed with this: http://www.fireballcoatings.com/inde...id=4&Itemid=12
AND
http://www.fireballcoatings.com/inde...id=8&Itemid=19
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
jjrbus
Jul 19, 2015 02:06 PM
Coreyr384
Jul 10, 2015 11:13 AM
